Software Archive
Read-only legacy content
17060 Discussions
hwloc-dump-hwdata[12799]: Couldn't find any KNL information.
Pawel_E_
hi guys,
I'm on Centos 7.5 and everything seemingly works except for this system service:
$ sudo journalctl -lf -o cat -u hwloc-dump-hwdata.service
Starting Dump hardware topology and locality information to /var/run/hwloc...
Dumping KNL SMBIOS Memory-Side Cache information:
hwloc-dump-hwdata.service: main process exited, code=exited, status=1/FAILURE
Failed to start Dump hardware topology and locality information to /var/run/hwloc.
Unit hwloc-dump-hwdata.service entered failed state.
hwloc-dump-hwdata.service failed.
A while ago something broke, with updates I presume. Would have any advice on how to rectify this?
many thanks, L.
JJK
New Contributor III
that service "just works" on my KNL box.
What happens if you run the 'hwloc-dump-hwdata'  as root ? does it return any KNL info?
If not, then perhaps the DMI bios info is not decoded properly. Post the output of
sudo strace /usr/sbin/hwloc-dump-hwdata 2>&1 | grep ^open
which on my box returns:
open("/proc/self/status", O_RDONLY)     = 3
openat(AT_FDCWD, "/sys/devices/system/node", O_RDONLY|O_NONBLOCK|O_DIRECTORY|O_CLOEXEC) = 3
open("/sys/devices/system/node/node0/meminfo", O_RDONLY) = 4
open("/sys/devices/system/node/node1/meminfo", O_RDONLY) = 4
open("/sys/devices/system/node/node2/meminfo", O_RDONLY) = 4
open("/sys/devices/system/node/node3/meminfo", O_RDONLY) = 4
open("/sys/devices/system/node/node4/meminfo", O_RDONLY) = 4
open("/sys/devices/system/node/node5/meminfo", O_RDONLY) = 4
open("/sys/devices/system/node/node6/meminfo", O_RDONLY) = 4
open("/sys/devices/system/node/node7/meminfo", O_RDONLY) = 4
openat(AT_FDCWD, "/sys/devices/system/cpu", O_RDONLY|O_NONBLOCK|O_DIRECTORY|O_CLOEXEC) = 3
openat(AT_FDCWD, "///sys/firmware/dmi/entries", O_RDONLY|O_NONBLOCK|O_DIRECTORY|O_CLOEXEC) = 3
open("///sys/firmware/dmi/entries/14-0/raw", O_RDONLY) = 4
open("///sys/firmware/dmi/entries/160-0/raw", O_RDONLY) = 4
open("///sys/firmware/dmi/entries/161-0/raw", O_RDONLY) = 4
open("/var/run/hwloc/knl_memoryside_cache", O_WRONLY|O_CREAT|O_TRUNC, 0644) = 3
Pawel_E_
That might be a problem, the BIOS of SYS-2027GR-TRT2
Inasmuch as Supermicro make really nice hardware they for reasons I cannot grasp, neglect their older products in terms of security. Which should be a MUST-NOT in days of spetre-meltdown. I've been waiting for a year, and still waiting, after I have exchanged emails with their tech support, for BIOS with fixes for those problems.
I see:
JJK
New Contributor III
errrrrr, a quick search on SYS-2027GR-TRT2 gave me this link: https://www.supermicro.com/products/system/2u/2027/sys-2027gr-trt2.cfm
which lists the mobo as an LGA2011 mobo, suitable for Xeon E5's only. Thus, there is Xeon Phi (KNL) on the mobo thus the "hwloc-dump-hwdata" has nothing to report.
Pawel_E_
Seem like (for you) I have to quote myself - A while ago something broke... - which means it was not a problem some time ago.
A quick (thorough) search shows that it's GPU/Xeon Phi dedicated system. In mine I have Xeon Phis.
JJK
New Contributor III
Please post the output of "lspci -v"  - my suspicion is that your box has Xeon Phi coprocessors; the command you mention is used on KNL (Xeon Phi x200) processors only.
Pawel_E_
But I just said I have Xeon Phis, more specifically:
83:00.0 Co-processor: Intel Corporation Xeon Phi coprocessor 31S1 (rev 11)
84:00.0 Co-processor: Intel Corporation Xeon Phi coprocessor 31S1 (rev 11)
I do not particularly need that command. I'm not sure if I need it at all. It just got installed with MPSS stack. I'm happy to remove it if it's no harm.
JJK
New Contributor III
the command and service were installed as part of the "hwloc" package. You can disable the systemd service using
systemctl disable hwloc-dump-hwdata.service
HTH, JJK
