Software Archive
Read-only legacy content
17060 Discussions
iOS APP ERROS BUILD
Lucas_Mauro_L_
Can anyone help me with this error?
I'm putting something wrong?
LOG ERROR: https://am-xdk2.s3.amazonaws.com/cust.6a3b013b-5e3d-49b2-bad8-bd70385e793c/app.425a7831-28c5-4fd1-a57c-bcb331933f87/iphone/build.201603164513.txt?AWSAccessKeyId=ASIAIRBGAW3UEQ4YF4FQ&Expires=1458168333&x-amz-security-token=AQoDYXdzEH0a4ANarXH1%2F6xshpdBGsVyIOEcFpA3wpiZYz3H%2B8pTUJqzn8ea6lyf1%2FNPQnrtEPc7RH7UtdQrhBeNQnLe%2FNJ9djPToMi15%2FoRfQhMH2umqNvUaUpqLmIL1rK%2FaF2m605soJqknFY13Wo95FScLWrbrrFUjeBj2AADk21Ap%2FzLCdWI%2BxhlC9V9e2a11RGZ1Zs99H8k0vmuSHcre8FbT7HK2wYLoC2rAg6OaC9yA%2BoVrpNgkECA4Ou4RJErbbgVfbUByoHHWLH%2FM3OUzdKm58SohLgCHJR2K3N%2FA1YwzLGLXibzwH3xZEsZ6Zo6HcoNIrbDPZzNBsHHNSMeb3cH4t7WqhXiseoSTwbKllVEBQEbO6ayiKp1tS7%2BI6BkfsaFw0LLzJtHjg1yvsTsQtyGrjntu0RuFXSlYsbLA%2F1MWqHx2y0ZBOXfitrYRq9WqDpmFsb2IHPy3h3U1pSLaquXfs7wgG3wMnON2aBuEcJu3b0PA4og4gAkXoQ7c0kEwKRImOiECOB7hF3sYJXVZHEAPmwSAJ1%2BrGB5lC7hfoiO517rkl2f29HUmolI2qNaoO4JCrJP04rOuE9YPT2uNIqVoxEScEITyRnvF8MgQlkYztWnvAGs8dW26ReVhK3Eb0QfMxQ709EgkuymtwU%3D&Signature=OhoVPwHJfPy%2FQn9N5dwf6rE%2B1c8%3D
Amrita_C_Intel
1. You need to create an AppID on Apples developer portal and then create a provisioning profile.
2. You must download the provisioning profile, and give it to the XDK in the project settings. Currently you are supplying a .cer file, this is incorrect.
3. This document should help you out. https://software.intel.com/en-us/xdk/articles/walkthrough-obtain-ios-appstore-adhoc-cert
Amrita_C_Intel
You can refer to this documentation as well: https://software.intel.com/en-us/xdk/docs/building-cordova-ios-apps-intel-xdk
Elroy_A_Intel
What Cordova plugins are you using? The errors that you are receiving is related to iOS app signing as seen below:
=== BUILD TARGET Gramado News OF PROJECT Gramado News WITH CONFIGURATION Release ===
Check dependencies
Code Sign error: No codesigning identities found: No codesigning identities (i.e. certificate and private key pairs) that match the provisioning profile specified in your build settings (“Gramado News”) were found.
Are you using the appropriate certificate (created via your Apple Developer Member Center) derived from the .csr file provided under the Build?
