Software Archive
Read-only legacy content
17060 Discussions
iOS BUILD FAILED - No error log
Samuel_C_
I'm building my app on Intel XDK, the app is ready and it works perfectly fine on android but when I try to export it for iOS it just fails.
There's always a message "BUILD FAILED" but there's not a proper BUILD LOG.
I can't find the error. Please help.
PaulF_IntelCorp
The app keeps saying BUILD ERROR.
Did you remove the lines I mentioned above, from your whitelist entries? When I did that the build succeeded. You need to clean out your whitelist, that's the source of the problem.
PaulF_IntelCorp
Usually this aborted build log is due to a problem the build server is having trying to add one or more of your plugins. To test that theory, you might remove your plugins, one-at-a-time, and perform a build after each removal, until you figure out which one is causing the problem.
Samuel_C_
I did that and It keeps failing.
PaulF_IntelCorp
These expressions won't work in the whitelist:
  • *https://*
  • *http://*
Putting an '*' in front of a protocol makes no sense.
BTW -- your whitelist settings include a '*' entry -- which means that all the other entries are irrelevant. If you are doing this for testing, that makes sense (assuming you'll be removing the '*' entry for production).
PaulF_IntelCorp
Samuel_C_
I forgot to remove one line.
Thank you so much for the support, now it works!
