Software Archive
Read-only legacy content
17060 Discussions
iOS Build error
BerndB
Hi Intel Team,
i have a problem renaming my App:
I already tested a lot and can say so far, that the issue is renaming the app with either
- a space in the app name or
- german "umlaut"
Can anyone help on this issue ?
It only happens with iOS builds on cordova CLI 5.1.1.
Tx in advance
Anusha_M_Intel1
App names can contain only alpha, space and numbers. No special characters. But your space should still be accepted.
What is the build error you are getting? I am trying this on my end too.
PaulF_IntelCorp
@Bernd -- if you create a blank project and give it the names in your example, do you still get the build failure you are posting? In other words, create a blank project and ONLY change the name to see if you get the build error.
