Software Archive
Read-only legacy content
17060 Discussions
iOS Production build: app instead of api
Olga_V_
Hi!
I use Intel SDK to build my hybrid Cordova app. Crosswalk app build for Android and AdHoc iOS build working well but when I try to build iOS Production I get a zip file .app instead of .ipa.
It looks like I miss something in configuration.
What can it be?
Thank you in advance,
Olga
Elroy_A_Intel
This is the app’s bundle. This directory contains the app and all of its resources.
You cannot write to this directory. To prevent tampering, the bundle directory is signed at installation time. Writing to this directory changes the signature and prevents your app from launching. You can, however, gain read-only access to any resources stored in the apps bundle. For more information, see the Resource Programming Guide for iOS
The contents of this directory are not backed up by iTunes. However, iTunes does perform an initial sync of any apps purchased from the App Store.
Olga_V_
I can't upload .zip file to iTunesConnect, can I?
John_H_Intel2
If you are getting a zip, you are building a Legacy build. You should switch to the Cordova builds. The Legacy builds will eventually going away since they are well, old. (hence the Legacy)
Yes, you can upload a zip with application loader.
