Software Archive
Read-only legacy content
17060 Discussions
iOS upload fails
John_V_1
I do not get any errors when building the app withing Intel XDK.
I uploaded to google and the app is live.
However the upload fails when uploading to Apple using application loader.  Here is the error.
ITMS-90046
Invalide code signing entitlements
Value '*' for key com.apple.developer.associated-domains
There is more but closed out the window accidentally. I rebuilt and resent same error.
John_V_1
Sorry rest of message is in Payload/MyApp.app/MyApp is not supported.
John_H_Intel2
You can not use * for your appID. You need to use something like com.myteam.myappname.
Also, you need to build for Distribuion (not ad hoc) to submit a build to the store.
John_V_1
Hi John H,
Thanks for your response. But I am not using * for appID ( it is org.ccbklyn.mobileapp ) and I am building for distribution.
Thanks, John V
John_V_1
I fixed the problem... I think. It did upload so...
In the apple certificate associated-domains was set to enabled on the developer site. I disabled and it worked. Not sure if I need associated domains or not however but I guess I will see.
