Software Archive
Read-only legacy content
17060 Discussions
ibscif/Infiniband problems
Christian_Goll
I am having problems with the actual mpss 3.2 relase in combination with CentOS 5.3 and the Intel 7.2.2.0.8 OFED stack.
The kernel version is 2.6.32-279-11.1 so I ahd to recompile the kernel modules.
As soon as I start the ofed-mic service, the infniniband connections on the host is not working any more (I tested this with a ibv_rc_pingpong). Communication with the card over scif0 interface is possible, but only with a poor bandwith (73.34 Mbit/sec). dmesg shows follwing supicous messages
IB Proxy Server v0.1 Build 6720-23
Copyright (c) 2011 Intel Corporation
ibscif: OpenFabrics IBSCIF Driver v0.1 Build 6720-23 built Mar 28 2014 12:12:04
ibscif: max_pinned=50, window_size=40, blocking_send=0, blocking_recv=1, fast_rdma=1, host_proxy=0, rma_threshold=1024, scif_loopback=1, new_ib_type=1
ibscif_add_one: my node_id is 0
RDMA CMA: cma_listen_on_dev, error -38, listening on device scif0
fmr_pool: Device scif0 does not support FMRs
Error creating fmr pool
ibscif_get_pollep_list: ep=ffff88086621a400 (0:listen)
ibscif_get_pollep_list: count=1
ibscif_do_connect: 0-->64625
ibscif_get_conn: ERROR: cannot get connection (0-->64625) after waiting, state=-1
ibscif_mr_get_mreg: conn==NULL
ibscif: ibscif_xmit_wr: fail to set up RMA addresses for the work request.
ibscif: ibscif_send_disconnect: ERROR: qp->conn == NULL
Does anybody have the same problems or know what I did wrong?
kind regards,
Christian
Frances_R_Intel
Just a quick note - the MPSS does not support any version of RHEL before 6.0 and in fact, earlier versions of RHEL have incompatibilities that will cause problems with the MPSS. Although CentOS is not explicitly supported in the MPSS, the RHEL support implies that CentOS 5.3 will have more problems than just OFED issues. The solution is to upgrade to a later version (6.0 or beyond) of CentOS.
Tommi_T_
He meant to write centos 6.3, not 5.3. Kernel which he is using indicates that (2.6.32-279-11.1)
Christian_Goll
I meant  centos 6.3, but it is not relevant any more as we haven a currently unsupported configuration with 2 Xeon Phi cards and only one Infiniband adapter.
kind regards,
Christian
TaylorIoTKidd
Christian,
How is your configuration unsupported? A configuration not being supported doesn't mean MPSS will not work, only that the MPSS team doesn't validate against it.
We do our best to help everyone who is using the coprocessor.
Please elaborate.
Taylor
Christian_Goll
Hello Taylor,
the main problem was that for the overlay filesystems located under
/var/mpss/mic[01]/
were working only for one of the two cards. The other one was then running only the with the base image. Which of the two cards was running with only the base image was completely arbitrary.
As we had another host image with an working older mpss version, I decided to wait for another mpss release.
kind regards,
Christian
Frances_R_Intel
Christian,
Just so we can make sure the problem isn't there in the next release, the problem showed up when you had:
two coprocessor cards (it's probably not important but do you know if they are C0 or B1 cards?)  running MPSS 3.2
one IB adapter (TrueScale as opposed to a Mellanox?) running Intel 7.2.2.0.8 OFED stack
with CentOS 6.3 and kernel version is 2.6.32-279-11.1
Is that correct?
And you tracked the problem down to one of the cards still running the initial boot RAM disk?. (The way the card boots, it first creates a RAM disk containing just the base file system, then later creates a second RAM disk containing both the base and overlays and switches to that disk. So not having the overlay files implies that the boot terminated while it was still using the first RAM disk image.)
Can you also tell me what MPSS version you are running now and if you are still using the same OFED and CentOS? And when you were running MPSS 3.2, did you try booting without OFED and then bringing that up later?
Frances
Tommi_T_
Do you see following error on the serial console which fails to boot correctly:
[    2.634597] Initramfs unpacking failed: junk in compressed archive
This happens before loading ofed-mic service and happens randomly. MPSS 3.2 and 3.2.1 are affected.
Christian_Goll
Hello Tommi,
yes I see exactly the junk message, just the time differs a bit
[    2.974297] Initramfs unpacking failed: junk in compressed archive
Is there a solution for this, except waiting for a new mpss release?
@Frances
Thw Ofed Stack is OFED-3.5-1-MIC-beta1
The MPSS is
mpss-3.2-rhel-6.3.tar
kind regards,
Christian
Michael_H_Intel1
I'm confused
 - which InfiniBand card?
 - which OFED stack - you are mentioning Intel 7.2.2.0.8 OFED and OFED-3.5-1-MIC-beta1
Tommi_T_
My setup:
Mellanox Technologies MT27500 Family [ConnectX-3]
2x Xeon Phi coprocessor SE10/7120
MPSS-3.2 + OFED 1.5.4 + el6.3 kernel seems to work
MPSS-3.2.1 + OFED-3.5-1-MIC-beta1 / OFED-3.5-2-MIC-beta2 + el6.5 kernel has this  "Initramfs unpacking failed"-problem
Tommi_T_
Today I tried mpss-3.2.1/ofed 1.5.4/el6.5 kernel combo and it still failed.
Btw, issues in this thread are too mixed, it's clear that author of this thread had some conflicting packages installed:
"SCIF Driver v0.1 Build 6720-23" vs. "I am having problems with the actual mpss 3.2 relase"
MPSS 3.x libscif build id should be 3.x, not 6720-23 which is from MPSS 2.x era.
Christian_Goll
Yes the topic and the issues in this thread are mixed. In order to clarify this, with all versions and combinations (I have tried several ones) I get the error
ibscif
Only with the newer release (3.2) I get the error with the junk  which makes only one of the cards usable, this error drove me nuts and so I have decided to wait for a new mpss, which hopefully will fix this.
Frances_R_Intel
Just to try to clean up here. The issue with the "Initramfs unpacking failed: junk in compressed archive" message, where only one card would come all the way up and the other would get stuck, was a corrupted image file. As Tommi found in the MPSS 3.2.3 release notes, there is a known problem where a corrupted mic0.img.gz file can be generated "if /var/mpss/mic0/... contains softlinks to files not existing in that file system tree", for example, if you are using OFED-3.5-1-MIC-beta1 / OFED-3.5-2-MIC-beta2. The recommendation is to use OFED 1.5.4.1. Also, everyone is being urged to move to the MPSS 3.2.3 release because it contains some important patches in it.
Will this "fix" the original problem with the InfiniBand connections on the host being lost? Probably, although the solution is not ideal for people who would rather be running a more recent version of OFED.
