Software Archive
Read-only legacy content
17061 ディスカッション
icl: : error #10310: Failed to enable trusted storage check for licensing
Ashutosh_P_
ビギナー
1,890件の閲覧回数
I just downloaded the evaluation version of Intel Parallel Studio XE 2015 cluster addition. I am trying to build a project in visual studio 2010 but it is giving me the following error:
icl: : error #10310: Failed to enable trusted storage check for licensing: WARNING: Enable Trusted Storage failed (flexnet error code 20). Trusted Storage based license could not be supported
It is similar to the problem discussed here for fortran: https://software.intel.com/en-us/forums/topic/531753
Thanks for your help,
Ashutosh
0 件の賞賛
9 返答(返信)
Hubert_H_Intel
従業員
1,890件の閲覧回数
Ashutosh,
I'll send you the license file as a workaround for the Trusted Storage problem. I guess you installed the product without serial number in the evaluation mode? Copy the license file (.lic) into c:\Program Files (x86)\Common Files\Intel\Licenses\ (for a 64-bit Windows OS) or c:\Program Files\Common Files\Intel\Licenses\ (for a 32-bit Windows OS). If this directory doesn't exist yet, create it and copy the license file into it.
Regards, Hubert.
Hubert_H_Intel
従業員
1,890件の閲覧回数
Ashutosh,
Sorry I need your email address under which you registered your eval license. Please resppond via "Send Author A Message".
Hubert.
Arnaud_G_
ビギナー
1,890件の閲覧回数
Hi Hubert,
I am having exactly the same problem as Ashutosh. Can you please also send me the temporary licence file if it solves the issue
Arnaud
Hubert_H_Intel
従業員
1,890件の閲覧回数
Arnaud,
Could you please tell me your email address via "Send Author A Message" under which you registered the eval?
Thanks, Hubert.
Peter_S_3
ビギナー
1,890件の閲覧回数
Hi Hubert,
I am experiencing the same issue but did not register my evaluation. Where can I register my evaluation?
Kind regards,
Peter
Ron_Green
モデレーター
1,890件の閲覧回数
Ankan_B_
ビギナー
1,890件の閲覧回数
I am also getting same error. Downloaded Intel® System Studio Composer Edition for Windows* 2015 for evaluation and didn't receive any serial number.
Guohong_Y_
ビギナー
1,890件の閲覧回数
me too,
the build log:
icl.exe /nologo /G5   /I"C:\Program Files (x86)\Intel\System Studio 2015 for Windows.2.020\compiler" /I"C:\Program Files\Intel\System Studio 2015 for Windows.2.020" /I"C:\Program Files (x86)\Intel\System Studio 2015 for Windows.2.020" /c D:\Cplusprogram\test1.c /FoD:\Cplusprogram\test1.obj
icl: error #10310: Failed to enable trusted storage check for licensing: WARNING: Enable Trusted Storage failed (flexnet error code 20). Trusted Storage based license could not be supported
Process terminated with status 1 (0 minute(s), 0 second(s))
0 error(s), 0 warning(s) (0 minute(s), 0 second(s))
Hubert_H_Intel
従業員
1,890件の閲覧回数
Guohong,
Another option would be to run icl the first time as administrator (if possible). Could you please try that out:
Start menu -> Intel Parallel Studio XE 2015 > Compiler and Performance Libraries > Command Prompt and open one with right-click -> 'Run as Administrator' and invoke icl without parameters.
That should help and is faster to work around than installing the license file. However, if this will not help, let me know and I'll send the license file.
Regards, Hubert.
返信
