The product is parallel_studio_xe_2011_sp1_update3_intel64
As soon as you click run, after the program is loaded idb just responds with the following:
[New Thread 47144 (LWP 47144)]
Cannot run thread, error #COULDNT_READ_REGISTER_VALUE
Program exited normally.
This was working fine, nothing on our end has changed.
could you provide me a simple reproducer for this problem?
When exactly do you see this error? Did the application already run for a while or does it occur right at the beginning?
Also, please let me know what OS you're running and whether it is 32 or 64 bit (OS and application).
Thank you & best regards,
Georg Zitzlsberger
Georg Zitzlsberger
It is running CentOS 6.3 (64-Bit)
Linux 2.6.32-279.2.1.el6.x86_64 #1 SMP Fri Jul 20 01:55:29 UTC 2012 x86_64 x86_64 x86_64 GNU/Linux
It occurs as soon as you try to run, never gets to user code.
It doesn't matter what program it is C/C++/Fortran even a simple "Hello World" in any of those languages, compiled with icc/gcc doesn't matter.
Doesn't matter if it is the command-line idbc/iidb or the GUI idb.
I just have the 64-bit of parallel studio installed, so they would all be 64-bit programs.
$ cat test.c
#include
int main(int argc, char *argv[])
printf("Hello World!\n");
$ icc test.c
$ ./a.out
Hello World!
$ idbc a.out
Intel® Debugger for applications running on Intel® 64, Version 12.1, Build [78.226.14]
object file name: a.out
Reading symbols from /a.out...done.
(idb) r
Starting program: /a.out
[New Thread 51646 (LWP 51646)]
(idb)
#include
$ icc test.c
$ ./a.out
Hello World!
$ idbc a.out
(idb) r
(idb)
Looks like there is a bug where if that initial thread (used for whatever by idb) gets a PID > 32767 it dies with that error.
Starting program: /home/suignard/a.out
[New Thread 32763 (LWP 32763)]
Hello World!
(idb) r
[New Thread 32765 (LWP 32765)]
Hello World!
(idb) r
[New Thread 32767 (LWP 32767)]
Hello World!
(idb) r
[New Thread 32769 (LWP 32769)]
(idb) r
[New Thread 32771 (LWP 32771)]
(idb) r
[New Thread 32775 (LWP 32775)]
(idb)
-then it works again once the pid wraps at 65536-
(idb) r
[New Thread 65530 (LWP 65530)]
(idb) r
[New Thread 65532 (LWP 65532)]
(idb) r
[New Thread 65534 (LWP 65534)]
(idb) r
[New Thread 300 (LWP 300)]
Hello World!
r(idb) r
[New Thread 302 (LWP 302)]
Hello World!
r(idb) r
[New Thread 304 (LWP 304)]
Hello World!
r(idb) r
[New Thread 306 (LWP 306)]
Hello World!
(idb)
Hello World!
(idb) r
Hello World!
(idb) r
Hello World!
(idb) r
(idb) r
(idb) r
(idb)
(idb) r
(idb) r
(idb) r
(idb) r
Hello World!
r(idb) r
Hello World!
r(idb) r
Hello World!
r(idb) r
Hello World!
(idb)
If anyone else is getting this error you can fix this by setting the pid_max kernel paramater to 32767 by (as root)
$ sysctl -w kernel.pid_max=32767
then edit /etc/sysctl.conf and add the line:
kernel.pid_max = 32767
I would still like intel to fix their issue though as I would like to increase this paramater on our development server again so we can verify our software works correctly with PIDs > 32767.
thank you for providing the workaround! I can confirm it. After talking with our engineers it was already fixed some weeks ago and will be first available with Intel® Composer XE 2013 (initial release), out beginning of September.
Unfortunately there won't be a fix for Intel® Composer XE 2011 anymore.
Georg Zitzlsberger
Georg Zitzlsberger
Topic Options
