Software Archive
Read-only legacy content
17060 Discussions
iframes blank in iOS, sample application
Richard_J_
I am testing the HTML5 Web Video Playback application.
When I build for iOS the youtube and vimeo iframes are blank. It looks like a permission issue. A local ifame from www/test.htm loads properly. I am using the default whitelist settings for the Web Video Playback application.
The iframes load properly in App preview, and for Android builds. Any idea what settings I need to make this work on iOS?
I am using Intel XDK 3240, Cordova CLI 5.4.1, iOS 9.3.2. Thanks.
Rakshith_K_Intel
In whitelist settings add "*" for all three:
Network Request(<access>)
Intent(<allow-intent>)
Navigation(<allow-navigation>)
I used these settings and was able to play youtube iframe embed.
my index.html:
<!DOCTYPE html>
<html>
<head>
    <meta http-equiv="Content-type" content="text/html; charset=utf-8">
    <meta name="viewport" content="width=device-width, initial-scale=1, user-scalable=no">
    <script src="cordova.js"></script>
</head>
<body>
    <iframe width="320" height="240" src="https://www.youtube.com/embed/-JUVzO8pqTk?rel=0" frameborder="0" allowfullscreen></iframe>
</body>
</html>
you can play around with these settings and use the appropriate ones.
Richard_J_
Rakshith - Thanks for the help. I had to set the project aside for a while, but I just tried your solution and it works. I appreciate it.
-Richard
Keith_T_
This problem happens when you go from building with Cordova CLI 5.1.1 to 5.4.1 or higher.
I solved this by setting "Network Request(<access>)" to * (although just *.vimeo.com should work). I left "Intent(<allow-intent>)" blank, and set "Navigation(<allow-navigation>)" to *.vimeo.com
The Whitelist for Android doesn't seem to have the Navigation section enabled yet, but I imagine the same problem will occur on Android if it is ever enabled.
