- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
I installed Warcraft - III game, in my computer, but just after starting the game , my computer gets hanged then it shows the following problem - "Windows - Display Driver Stopped Responding. Theigxprd32 display driver has stopped working normally. Save yourwork and reboot the system to restore full display functionality."
i thought the game is not supporting my computers config, but when i used "system requirement labs" game compatibility tool it clearly shows that the game will run in my computer. then i updated chipset, graphics & audio driver, but still i face the problem.
my computer configuration is as follows -
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_gdr.080814-1236)
Language: English (Regional Setting: English)
System Manufacturer: INTEL_
System Model: ECG3510M
BIOS: Default System BIOS
Processor: Intel Core2 Quad CPU Q6600 @ 2.40GHz (4 CPUs)
Memory: 1014MB RAM
Page File: 477MB used, 1966MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.5512 32bit Unicode
display information -
Card name: Intel G35 Express Chipset Family
Manufacturer: Intel Corporation
Chip type: Intel GMA X3500
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_2982&SUBSYS_D7018086&REV_03
Display Memory: 384.0 MB
Current Mode: 1024 x 768 (32 bit) (60Hz)
Monitor: Default Monitor
Monitor Max Res:
Driver Name: igxprd32.dll
Driver Version: 6.14.0010.5009 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 11/3/2008 09:47:20, 57344 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: igxpmp32.sys
Mini VDD Date: 11/3/2008 09:46:34, 6273504 bytes
Device Identifier: {D7B78E66-6AC2-11CF-A7F0-0BF7A2C2CB35}
Vendor ID: 0x8086
Device ID: 0x2982
SubSys ID: 0xD7018086
Revision ID: 0x0003
Revision ID: 0x0003
Video Accel:
Deinterlace Caps: n/a
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Not Available
sound devices -
Description: Realtek HD Audio output
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0888&SUBSYS_8086D701&REV_1001
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: RtkHDAud.sys
Driver Version: 5.10.0000.5735 (English)
WHQL Logo'd: Yes
Date and Size: 11/11/2008 17:21:52, 4946944 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 8000, 192000
Static/Strm HW Mix Bufs: 33, 32
Static/Strm HW 3D Bufs: 33, 32
HW Memory: 0
Voice Management: No
EAX 2.0 Listen/Src: Yes, Yes
I3DL2 Listen/Src: Yes, Yes
Sensaura ZoomFX: No
Registry: OK
Link copiado
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Memory: 1014MB RAM
Windows Dir: C:WINDOWS
DAC type: Internal
Device Key: EnumPCIVEN_8086&DEV_2982&SUBSYS_D7018086&REV_03
Monitor Max Res:
WHQL Logo'd: Yes
VDD: n/a
Vendor ID: 0x8086
Device ID: 0x2982
Revision ID: 0x0003
Revision ID: 0x0003
Video Accel:
Registry: OK
D3D Status: Enabled
sound devices -
Hardware ID: HDAUDIOFUNC_01&VEN_10EC&DEV_0888&SUBSYS_8086D701&REV_1001
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF5F
HW Memory: 0
Sensaura ZoomFX: No
Registry: OK
I had the same problem , and solved it installing the 1433 version of the drivers ( win2k_xp1433.exe ) hope this help.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
I have a similar problem, but I have a mobile intel 965 Express Chipset Family integrated graphics.
If I use Firefox or play games when the following message appears "Windows - Display Driver Stopped Responding. Theigxprd32 display driver has stopped working normally"and "Save yourwork and reboot the system to restore full display functionality."
I tried older and newer drivers, but the Drivers didn't help.
Can someone help me?
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
I have the same problem. My Laptop notebook is ACER Aspire 4720 which has Intel graphic medai accelerator X3100
Or Intel Chipset 965 (on board)
Plz, Answer our question if this problem has the method to solve. Thanks
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
However, after doing some googling, I have found this:
if you append some of these three things after the "Target:" in shortcut properties, the game will run normally.
-swtnl (software transform and lightning, the processor now does everything instead of the graphics card)
-openg
-d3d (the default, but somehow if it is not there, it will CRASH)
It has to look like this one:
"C:Warcraft IIIFrozen Throne.exe" -d3d
I am using the third one, but I have to admit that once the driver crashed EVEN with the third one in place. But I think that was just a coincidence.
I know that GM965 (x3100) is not intended to run games. But with the previous version of the driver it WORKED, so why it shouldn't keep working in the newer ones?
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
So either you have to use the older driver as was said in the second or third post, or you use the "-swtnl" or "-opengl" flags.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Enjoy and have a good gaming experience!
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
-openg
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
You have to do a driver downgrade!!!!! and you'll fix the problem.
Here is the URL where you can download the file:
http://www.megaupload.com/?d=ZQ4F03XQ
and this are the specification:
Production Version Releases
* Microsoft Windows* XP
* Driver Revision: PV 14.31
* Package: 38711
* Graphics: 6.14.10.4859
* HDMI Audio: 5.10.0.1030
* August 10, 2007
* NOTE: This document refers to systems containing the
* following Intel chipsets:
* Intel 945G Express Chipset
* Intel 945GZ Express Chipset
* Intel 946GZ Express Chipset
* Intel G35 Express Chipset
* Intel G965 Express Chipset
* Intel Q963 Express Chipset
* Intel Q965 Express Chipset
* Mobile Intel 940GML Express Chipset
* Mobile Intel 943GML Express Chipset
* Mobile Intel 945GM Express Chipset
* Mobile Intel 945GME Express Chipset
* Mobile Intel 945GMS Express Chipset
* Mobile Intel GLE960 Express Chipset
* Mobile Intel GM965 Express Chipset
* Mobile Intel GME965 Express Chipset
Bye bye, and enjoy warcraft 3 ;)
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
* Package: 38711
* August 10, 2007
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Memory: 1014MB RAM
DAC type: Internal
Monitor Max Res:
WHQL Logo'd: Yes
VDD: n/a
Vendor ID: 0x8086
Device ID: 0x2982
Revision ID: 0x0003
Revision ID: 0x0003
Video Accel:
Registry: OK
D3D Status: Enabled
sound devices -
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF5F
HW Memory: 0
Sensaura ZoomFX: No
Registry: OK
------------DxDiag Notes------------ DirectX Files Tab: No problems found. Display Tab 1: No problems found. Sound Tab 1: No problems found. Sound Tab 2: No problems found. Music Tab: No problems found. Input Tab: No problems found. Network Tab: No problems found.
--------------------DirectX Debug Levels--------------------Direct3D: 0/4 (n/a)DirectDraw: 0/4 (retail)DirectInput: 0/5 (n/a)DirectMusic: 0/5 (n/a)DirectPlay: 0/9 (retail)DirectSound: 0/5 (retail)DirectShow: 0/6 (retail)
---------------Display Devices--------------- Card name: Intel G965 Express Chipset Family Manufacturer: Intel Corporation Chip type: Intel GMA X3000 DAC type: Internal Device Key: Enum\PCI\VEN_8086&DEV_29A2&SUBSYS_514D8086&REV_02 Display Memory: 128.0 MB Current Mode: 1152 x 864 (32 bit) (60Hz) Monitor: Default Monitor Monitor Max Res: Driver Name: igxprd32.dll Driver Version: 6.14.0010.5016 (English) DDI Version: 9 (or higher)Driver Attributes: Final RetailDriver Date/Size: 12/12/2008 10:34:42, 57344 bytes WHQL Logo'd: Yes WHQL Date Stamp: n/a VDD: n/a Mini VDD: igxpmp32.sys Mini VDD Date: 12/12/2008 10:33:58, 6048768 bytesDevice Identifier: {D7B78E66-6AE2-11CF-AEF0-4771A3C2CB35} Vendor ID: 0x8086 Device ID: 0x29A2 SubSys ID: 0x514D8086 Revision ID: 0x0002 Revision ID: 0x0002 Video Accel:Deinterlace Caps: n/a Registry: OK DDraw Status: Enabled D3D Status: Enabled AGP Status: Not AvailableDDraw Test Result: Not runD3D7 Test Result: Not runD3D8 Test Result: Not runD3D9 Test Result: Not run
- Marcar tópico como novo
- Marcar tópico como lido
- Marcador
- Subscrever
