Software Archive
Read-only legacy content
17060 Discussions
installation error on Windows 7 with VS 2005 and VS 2008 installed
sarangclaron
I am installing Intel C++ compiler professional ver 11.1.065 on Windows 7 64bit w/ Visual Studi 2005 and 2008 both installed. In the installation process, I reach "Processing package 6 of 9..." state when this error pops up: "Error 1722. There is a problem with this Windows Installer Package. A program run as part of the setup did not finish as expected. Action CMM_RunDevenv2008, location:..., command: /setup /nosetupvstemplates"
I searched everywhere but I cannot find a solution. Please suggest how I can resolve this error.
Igor_V_Intel
Dear customer,
Please try to deselect Intel Parallel Debugger Extension during thesetup.
After that try to install only this component.
The Error 1722 means that there is somthing wrong in uninstalling some components. So, I guess that you have other versions of the compiler installed, right?
I found similar issue in our database, but the solution is not clear. The customer got something wrong in the operation system and just run the installer again toinstall the whole package finally.
Igor
sarangclaron
Some more information from the installation Log (the error 1722 is towards the end):
MSI (s) (AC:E4) [16:25:22:901]: Executing op: CleanupConfigData()
MSI (s) (AC:E4) [16:25:22:901]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\113F607A8685A3044AC8001B9F03258D\Patches 3: 2
MSI (s) (AC:E4) [16:25:22:901]: Executing op: RegisterPatchOrder(Continue=0,SequenceType=1,Remove=0)
MSI (s) (AC:E4) [16:25:22:901]: Note: 1: 1402 2: UNKNOWN\Products\113F607A8685A3044AC8001B9F03258D\Patches 3: 2
MSI (s) (AC:E4) [16:25:22:902]: Executing op: ProductPublish(PackageKey={F0A39216-DDA0-43BA-85E0-874178D7A97B})
MSI (s) (AC:E4) [16:25:22:902]: Note: 1: 1402 2: UNKNOWN\Installer\Products\113F607A8685A3044AC8001B9F03258D 3: 2
MSI (s) (AC:E4) [16:25:22:907]: Executing op: UpgradeCodePublish(UpgradeCode={F4618FA6-D378-45F2-953D-60C8D74C3F66})
MSI (s) (AC:E4) [16:25:22:907]: Executing op: SourceListPublish(,,DiskPromptTemplate=[1],,NumberOfDisks=1)
MSI (s) (AC:E4) [16:25:22:907]: Note: 1: 1402 2: UNKNOWN\Installer\Products\113F607A8685A3044AC8001B9F03258D\SourceList 3: 2
MSI (s) (AC:E4) [16:25:22:910]: Executing op: ProductPublishClient(,,)
MSI (s) (AC:E4) [16:25:22:911]: Executing op: SourceListRegisterLastUsed(SourceProduct={A706F311-5868-403A-A48C-00B1F93052D8},LastUsedSource=C:\Program Files (x86)\Intel\Download\w_cproc_p_11.1.065\Installs\1033\w_cproc_idb_vs_p_11.1.065\)
MSI (s) (AC:E4) [16:25:22:911]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI (s) (AC:E4) [16:25:22:911]: Setting cached product context: machine assigned for product: 113F607A8685A3044AC8001B9F03258D
MSI (s) (AC:E4) [16:25:22:911]: Specifed source is already in a list.
MSI (s) (AC:E4) [16:25:22:911]: User policy value 'SearchOrder' is 'nmu'
MSI (s) (AC:E4) [16:25:22:911]: Adding new sources is allowed.
MSI (s) (AC:E4) [16:25:22:911]: Set LastUsedSource to: C:\Program Files (x86)\Intel\Download\w_cproc_p_11.1.065\Installs\1033\w_cproc_idb_vs_p_11.1.065\.
MSI (s) (AC:E4) [16:25:22:911]: Set LastUsedType to: n.
MSI (s) (AC:E4) [16:25:22:911]: Set LastUsedIndex to: 1.
MSI (s) (AC:E4) [16:25:22:912]: Executing op: ActionStart(Name=CMM_RunDevenv2005,Description=Configuring Microsoft Visual Studio* software,)
MSI (s) (AC:E4) [16:25:22:913]: Executing op: CustomActionSchedule(Action=CMM_RunDevenv2005,ActionType=1586,Source=C:\Program Files (x86)\Microsoft Visual Studio 8\Common7\IDE\devenv.exe,Target=/setup,)
MSI (s) (AC:E4) [16:25:22:913]: Executing op: ActionStart(Name=CMM_RunDevenv2008,Description=Configuring Microsoft Visual Studio* software,)
MSI (s) (AC:E4) [16:25:22:913]: Executing op: CustomActionSchedule(Action=CMM_RunDevenv2008,ActionType=1586,Source=C:\Program Files (x86)\Microsoft Visual Studio 9.0\Common7\IDE\devenv.exe,Target=/setup /nosetupvstemplates,)
MSI (s) (AC:E4) [16:25:22:913]: Executing op: End(Checksum=0,ProgressTotalHDWord=0,ProgressTotalLDWord=29408807)
MSI (s) (AC:E4) [16:25:22:915]: User policy value 'DisableRollback' is 0
MSI (s) (AC:E4) [16:25:22:915]: Machine policy value 'DisableRollback' is 0
MSI (s) (AC:E4) [16:25:33:697]: Note: 1: 1722 2: CMM_RunDevenv2008 3: C:\Program Files (x86)\Microsoft Visual Studio 9.0\Common7\IDE\devenv.exe 4: /setup /nosetupvstemplates
CustomAction CMM_RunDevenv2008 returned actual error code -2146233082 (note this may not be 100% accurate if translation happened inside sandbox)
MSI (s) (AC:E4) [16:48:56:925]: Product: Intel Parallel Debugger Extension for Microsoft Visual Studio, version 11.1.065 -- Error 1722.There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor. Action CMM_RunDevenv2008, location: C:\Program Files (x86)\Microsoft Visual Studio 9.0\Common7\IDE\devenv.exe, command: /setup /nosetupvstemplates
MSI (s) (AC:E4) [16:48:56:927]: Executing op: Header(Signature=1397708873,Version=500,Timestamp=1023640364,LangId=1033,Platform=0,ScriptType=2,ScriptMajorVersion=21,ScriptMinorVersion=4,ScriptAttributes=1)
MSI (s) (AC:E4) [16:48:56:927]: Executing op: DialogInfo(Type=0,Argument=1033)
MSI (s) (AC:E4) [16:48:56:927]: Executing op: DialogInfo(Type=1,Argument=Intel Parallel Debugger Extension for Microsoft Visual Studio, version 11.1.065)
Igor_V_Intel
Dear customer,
Igor
sarangclaron
Thanks for the helpful answer! What worked was deselcting the Parallel debugger extension during setup.
Just to complete the loop, I did not have any Intel compiler installed prior to this attempt. I had both VS 2005 and 2008 installed. Also, installing again did not help either.
Thanks again!
