Software Archive
Read-only legacy content
17060 Discussions
intel G33 in Shuttle SG33G5M - PowerDVD graphic card not supported
raulvg
How to workaround intel G33 graphic card not supported message when i try to play Blue Ray disk in PowerDVD software?
Thank's a lot
raulvg@venasegovia.com
Aaron_B_Intel
Which graphics driver version are you using?
PowerDVD should support 15.4.50, 15.6.1, and 15.7 (or higher). In some cases, I've seen that people have to rebuild their Vista machine from the ground up, installing Intel drivers first, then installing PowerDVD Ultra after the Intel drivers are in place.
raulvg
Intel Graphics Media Accelerator driver 6.14.10.4837
Information from intel graphics tool
Windows XP SP2 + Updates + PowerDVD Ultra + Intel Graphic Update
Aaron_B_Intel
Ah, XP.
Intel graphics don't support content protection for HD DVD/Blu-ray intheir XP drivers, so PDVD Ultra won't work in XP.
raulvg
ok. I should install windows vista and it's work fine?
Thank's
Aaron_B_Intel
I've seen people get it working on Vista.
raulvg
Ok. It's working !!!!!!!!!!!!
Thank you very much.
user125
Vista stinks, Is intel ever planning to make xp drivers that will work with powerdvd? I have too many apps that don't work in vista, so I don't want to upgrade. But I now have a bluray/hddvd pc drive thats sitting here doing nothing.
osirion
Vista isnt that bad - its just very resource intensive :P
user125
Well regardless, I want to play blue ray on my powerdvd ultra on windows xp with my intel g33 drivers. Is there any plans to make one?
Aaron_B_Intel
No
weirdgod
Why is it taking so long for Intel to produce anything software related? We have waited sooo long for directx10 drivers for X3000 architecture, now again a problem with support for powerdvd... And at the same time you guys want to compete with nvidia and ati/amd on graphics side? Pha...
Dean
Web directory
drone79
Hi archibael,
i am also interested in drivers with real HDCP support for Windows XP. Are there any beta drivers or other third party drivers available?
I getting really frustrated about Intels politics concerning this issue. I paid a lot of money for my new hardware. Now i must buy another graphics card or windows vista to get
my blu ray sytem running?
drone
Aaron_B_Intel
Intel's official policy, at this time, is that WinXP is not supported for Blu-ray. I am uncertain on the rationale for this-- it probably has to do with the difficulty of securing the video path on the older XP software stack.Presumably Vista has specific functionality which makes this more reasonable.
HDCP, in particular, actually is a separate issue, and is supported on both XP and Vista. I can't for the life of me think of any application besides Blu-ray which would actually use it, but assuming someone wanted to design a Cable Card DVR based on Intel graphics and WinXP and needed HDCP it would be there.
I'm not thrilled about it myself, as I have a nice old copy of WinXP I am running on, but I have seen no movement on this front in the last year or so and don't think there will be any.
All of which I knew when I purchased it, so my complaints are primarily self-directed.
drone79
Thanks for the info.
orangrayshade
thanks, i help me a lot..
mtlucerotxhotmail_co
Quoting - archibael
Archibael, I recently reviewed this thread and installed the 15.4.50 driver. I am on Vista 32 bit and have installed an LG GGC-H20L BD/HD-DVD player that bundled with PowerDVD Ultra. The software will not allow the playback still. Per Cyberlink, I am required to have 15.8 or higher. I have not been able to locate it on the Intel site. Thanks.
Raul, I'm having the same problem and have tried installing the 15.4.5 driver with no good result. can you let me know what you did to get this running? I'm on Vista 32, Thanks..
Aaron_B_Intel
emmahenley
I can't for Blu-ray.
Intel's official policy, at this more reasonable.
HDCP, in particular, actually is not supported for the life of me think of any application besides Blu-ray which would actually use it, but I have a nice old copy of securing the difficulty of WinXP I am running on, but assuming someone wanted to do with the video path on the older XP software stack. Presumably Vista has specific functionality which makes this time, is that WinXP is a separate issue, and needed HDCP it would be there.
All which I knew when I purchased it, so my complaints are primarily self-directed.
I am uncertain on Intel graphics and WinXP and is supported on both XP and Vista.
I'm not thrilled about it probably has to design a Cable Card DVR based on the rationale for this-- it myself, as I have seen no movement on this front in the last year or so, and don't think there will be any.
Emma Henley
Sidekick Phones - Sidekick Phones - 32 HDTV LCD
la_toile
I'm using a G33 express chipset with VISTA 32 and I cannot play Blu-Ray with Power DVD ("graphic card not supported). The detailed post is at the followink link:
http://software.intel.com/en-us/blogs/2007/09/13/what-a-graphics-software-developer-community-at-intel/#comment-20766
Can you please support me how to make it working
Thanks in advance!
