Software Archive
Read-only legacy content
17060 Diskussionen
intel i3, i5 or i7???
Mariana_C_
Einsteiger
1.267Aufrufe
hi,
I decided to buy a new PC to work with the camera and I have the choice between Intel i3 or i5 processor, both 4. generation.
Which would you recommend to use the camera?
thanks in advance!
Mariana
6 Antworten
MartyG
Geehrter Beitragender III
1.267Aufrufe
So far, I and a couple of other people I have seen have had success with the camera using an i3 CPU.  This is also the CPU used in Intel's own NUC mini-PC, which apparently has very strong compatibility with the camera.
Having said that, in theory an i5 should work as well since both CPUs are 4th Generation.  An i5 PC may be a bit faster but also more expensive. I can't speak personally for how well an i5 works since I don't have one, but I've had no problems at all with the camera with my i3.
Mariana_C_
Einsteiger
1.267Aufrufe
Thank you Marty G, your answer is very helpful!
m
Dirk_R_
Einsteiger
1.267Aufrufe
I've just bought an Intel NUC with an I5.
At least the price is also a question of RAM and SSD.
I've added 16 GB RAM and 512 GB SSD.
8 RM and 256 GB SSD is also ok.
MartyG
1.267Aufrufe
I reduced my upgrade costs by choosing a compatible motherboard that supported the DD3 memory I already had so that I didn't have to buy new memory sticks.
A NUC is a safer option though if you are not comfortable with sticking your hands inside a machine and rearranging its guts.  :)
Mariana_C_
Einsteiger
1.267Aufrufe
Thanks!
The NUC looks like a very good choice!
I never worked with one, are no problems with graphic card?
MartyG
1.267Aufrufe
I've seen a few people on this forum who have bought a NUC and been very happy with it, and it has worked fine out of the box with the camera without having to install any extra parts.
Antworten
