Software Archive
Read-only legacy content
17060 Discussions
intel parallel studio XE evaluation building in x64- licence error
alexandre_c_1
I have download the evaluation version of intel parallel Studio XE  composer in order to test the Fortran compiler in 64 bits
I was able to build in win32 but whenever I am trying to build in x64 it does not work. I get the following message.
Error 1  error #10310: Failed to enable trusted storage check for licensing: WARNING: Enable Trusted Storage failed (flexnet error code 20). Trusted Storage based license could not be supported ifort
I have installed the program having the admin rights but it did not work.
Can someone help me with this licence problem ?
Thank you
Devorah_H_Intel
I sent you the license file. This should help. Please let me know if you need further help.
Devorah
Intel® Developer Support
alexandre_c_1
Good Morning,
I am now getting the error (error #10310: Failed to enable trusted storage check for licensing: WARNING: Enable Trusted Storage failed (flexnet error code 20). Trusted Storage based license could not be supported     ifort)
I suspect it is cause by the expiry of my demo license.
I would like to know if it is possible to have an extension of my demo license for parallel studio xe composer for fortan.
Our office is buying the software but we are expecting administrative delay.
Thank you
Devorah_H_Intel
I have sent you a private message for additional information.
Devorah
