Software Archive
Read-only legacy content
17060 Discussions
intel@ realsense Depth camera manager SR300 setup wizard ended prematurely because of an error
lin_k_
     intel@ realsense Depth camera manager  SR300 setup wizard ended prematurely because of an error.
     Windows installer failed to configure product:
     Error message:a serious error durin installation
     Error code:1603
     file name:intel_rs_sdk_runtime_intel64_capi_ivcam_1_4_27_59748.msi
     To install this program at a later time, run Setup Wizard again. Click the Finish button to exit the Setup Wizard.
     Build number:intel_rs_dcm_sr300_3.0.24.59748
     I am running windows 8.1,and installed microsoft visual studio 2010.And R200 successful insallation.
     I try to reinstall system,but still fail.
     What do I do now?
samontab
Valued Contributor II
I think SR300 needs windows10 though...
PKusm
I was having the same issue. Then I tried running the SR300 DCM installer on Windows 8 compatibility and it runs successfully. Now, I am able to run one of my apps which uses 3D seg module on SR300.
However, it is also worth knowing that Intel suggests SR300 to be run on Win.10 build 10586.
Dan_S_Intel1
Same here. Run in compatibility mode - windows 8(Right click, properties and go to compatibility tab) resolved the problem.
John_P_9
I have Windows 10 Pro build 10586.420 but I get the 1603 Error with the latest driver intel_rs_dcm_sr300_3.1.25.2599.
If I try to set Windows compatibility to Win8 it fails - only runs under WIndows 10
I found an instruction about installing using an INF from a zip file - anyone know where I can find that? Or is intel_rs_dcm_sr300_3.0.24.59748  still available somewhere?
John
John_P_9
The problem was my desktop - an oldish AMD. I installed on a new HP SPectre 360 and it worked straight away
