Software Archive
Read-only legacy content
ionic form
nicolas_r_
Hi i im working whit ionic as framework  but i have some trouble i need to get data from some input and save it, to send them by JSON this is the structure that im using and i need to get the label and the selected item. i also want to try an alert when the data is send.
<div class="list">
                        <div class="list">
                            <form ng-submit="submitEvent(event)">
                            <label class="item item-input">
                                <span class="input-label">Rut</span>
                                <input type="text" ng-model="event.rut">
                            </label>
                                <span class="input-label">Nombre</span>
                                <input type="text" ng-model="event.nombre">
                            </label>
                                <span class="input-label">Apellido</span>
                                <input type="text" ng-model="event.apellido">
                            </label>
                                <span class="input-label">Telefono</span>
                                <input type="text" ng-model="event.telefono">
                            </label>
                            <label class="item item-input item-select">
                            <div class="input-label">
                                Region
                            </div>
                            <select>
                                <option>XIV Los Rios</option>
                            </select>
                            </label>
                                Comuna
                            </div>
                            <select>
                                <option>Valdivia</option>
                                <option>Mariquina</option>
                                <option>Lanco</option>
                                <option>Mafil</option>
                                <option>Corral</option>
                                <option>La Union</option>
                                <option>Paillaco</option>
                                <option>Los Lagos</option>
                                <option>Rio Bueno</option>
                                <option>Futrono</option>
                                <option>Panguipulli</option>
                                <option>Lago Ranco</option>
                            </select>
                            </label>
                  Tipo de Sangre
                </div>
                <select>
                            <option>A+</option>
                            <option>A-</option>
                            <option>B+</option>
                            <option>B-</option>
                            <option>AB+</option>
                            <option>AB-</option>
                            <option>0+</option>
                            <option>0-</option>
                 </select>
                </label>
                            </form>
                        </div>
<button class="button widget uib_w_54 d-margins button-assertive" data-uib="ionic/button" data-ver="0">Enviar</button>
