Software Archive
Read-only legacy content
17061 Discussions
is the vectorlength clause merely a hint to the compiler?
Aldy_Hernandez
Hi.
There is a small discussion going on in the GCC mailing list wrt the vectorlength clause (http://gcc.gnu.org/ml/gcc-patches/2013-04/msg01333.html). This is in regards to the vectorlength attribute as it relates to the Cilk Plus #pragma simd construct.
The question is, whether vectorlength is just a hint to the compiler, basically "if you vectorize, prefer this vector length, but the compiler is still responsible for doing any (dependency/etc) analysis, and punting if it can't prove there is no aliasing (or go for runtime checks)".
All I see in the spec is "If the vectorlength clause is used, the VL is selected from among the values of its arguments".  Is this merely a hint?  What if the compiler can't use the vectorlength specified, is this a hard error?  Should we fail?  Is the vectorlength clause an assertion that no further dependence analysis will be done by the compiler, and the following loop is guaranteed to be vectorizable?
Any tips would be greatly appreciated.  Thanks.
Aldy
Pablo_H_Intel
When using #pragma simd, the programmer is asserting that there are no loop-carried dependencies and that the iterations can be evaluated in parallel.  The compiler is not responsible for "prooving" this assertion -- it can assume it's true and vectorize accordingly.
Vectorlength is mostly a hint to the compiler, but it does have a subtle semantic meaning.  When used with #pragma simd, the the vectorlength clause tells the compiler that there are no loop-carried dependencies within a specified window as specified in the vectorlength clause.  For example, for vectorlength(8), iteration j can depend a value computed in iteration j - 8, but not on a value computed in j - 7.  If vectorlength is not specified, it defaults to the entire loop count, i.e., no loop-carried dependencies at all. The compiler is never required to use a specific vector length; it is permitted to choose any vector length less than or equal to length specified in the vectorlength clause.
Clarifying this meaning is at the top of my list for the next revision of the Cilk Plus language specification.
-Pablo
Aldy_Hernandez
Ok, that's a lot clearer.  Thanks.
I assume that if there are multiple vectorlength arguments, then we can depend on the MAX of the arguments?  That is, for vectorlength(8,4), then there can be dependencies on MAX(8,4), j - 8, but not j - 4, or j - 2, etc.
Thanks again,
Aldy
Pablo_H_Intel
Correct.  The use of multiple vectorlength arguments is being removed (or at least deprecated) in the next revision of the spec., since it carries no semantic meaning and is not even a very good hint to the compiler.
-Pablo
TimP
The OpenMP 4.0 RC2 draft standard defines #pragma omp simd safelen(length)
TimP
In current Intel compilers, apparently #pragma omp simd safelen is implemented for targets -mavx and -mmic, but ignored for older architectures.
I haven't seen a decision made in view of OpenMP 4.0 on changing the past marketing point of view that all #pragma simd are considered part of Cilk(tm) Plus.
