Hi all,
I'm very new to scripting and coding so I might not get through to you guys but I hope this attempt goes straight to the point so I don't bore you.
So I've been searching online for an example javascript like the window.open and noticed this. https://software.intel.com/en-us/node/493021. How do you make it work to where you click on a button on a IOS app to natively open Safari to the preferred website. Can anyone show me a link or post an example so that I can try it?
- Tags:
- HTML5
- Intel® XDK
If I understood you, I think you need something like this:
In .js file:
function funAbreURL(cURL) {
intel.xdk.device.launchExternal(cURL);
$(document).on("click", "#spaLinkHTS", function () {
funAbreURL("http://www.hts-net.com.br/");
In HTML file:
<span id="spaLinkHTS" class="links">
<img src="imagens/logo_hts.gif" style="text-align: center; float: right;" alt="HTS Informática" data-appbuilder-object="image" class="" title="">
</span>
See the Cordova inAppBrowser plugin: http://plugins.cordova.io/#/package/org.apache.cordova.inappbrowser or https://github.com/apache/cordova-plugin-inappbrowser/blob/master/doc/index.md
