Software Archive
Read-only legacy content
17060 Discussions
known issue 3900: Mac "Command" key
Bob_Smith__Bethany_S
Depressing the Mac "Command" key in an edit window (on the Develop tab) causes source code lines to "undent" (the "Command-[" function).
Any possible idea when this crazy frustrating bug will be addressed or suitable workaround published?  'not pressing the cmd key isn't really a suitable workaround...
Bob.
PaulF_IntelCorp
It has been addressed in the upcoming hotfix. It was due to a Brackets bug.
Muchas Gracias - ETA on fix, thanks?
PaulF_IntelCorp
We're hoping to have the hotfix out ASAP, release candidates are being generated, but I am not allowed to publish a release date.
Namık_Zafer_E_
Until hot fix, Mr Bob, you can use this extension below
https://github.com/redmunds/brackets-display-shortcuts
In Intel XDK, select Extension Manager, install "Display Shortcuts". After them, open help tab, select "Show Shortcuts". Then you can remove these shortcuts "Command-[" and "Command-]" by left click and selecting "Disable Shortcut". After disable, you can see below keymap.json
    "documentation": "https://github.com/adobe/brackets/wiki/User-Key-Bindings",
    "overrides": {
        "Cmd-]": null,
        "Cmd-[": null,
        "Ctrl-Alt-I": null
God Bless you Namık Zafer E....
gaston-hillar
Valued Contributor I
Namik,
Thank you so much for sharing this configuration tweak!
