Software Archive
Read-only legacy content
17060 Discussions
linker errors
katoba88
I'm trying to link a VF app with Tcl: when I link the following code with my application I get the subsequent link error. The required static libraries have been included in the settings, and I don't think name decoration is the problem. Any ideas. (the Tcl .libs also require dlls at runtime - calling problem here?)
 tclint.c, a simple Tcl interpreter.
#include
#include
#include
Tcl_Interp* interp;
int TclEvalFile()
	int         status;
	char* string;
	string = "hello.tcl";
        status = TCL_OK;
        status = Tcl_EvalFile(interp, string);
        /* Print result string. */
        if (interp->result != NULL) {
            printf("TCL: [%s]
", interp->result);
  return status;
int TclCreateInterp()
    interp = Tcl_CreateInterp();
    return 0;
int TclDeleteInterp()
   /* Free memory for interpreter. */
    Tcl_DeleteInterp(interp);
    return 0;
LINK : warning LNK4098: defaultlib "LIBCD" conflicts with use of other libs; use /NODEFAULTLIB:library
saratcl.obj : error LNK2001: unresolved external symbol __imp__Tcl_EvalFile@8
saratcl.obj : error LNK2001: unresolved external symbol __imp__Tcl_CreateInterp@0
saratcl.obj : error LNK2001: unresolved external symbol __imp__Tcl_DeleteInterp@4
../sara3d.exe : fatal error LNK1120: 3 unresolved externals
Error executing link.exe.
sara3d.exe - 4 error(s), 1 warning(s)
Steven_L_Intel1
First, it would appear you are building a debug configuration. Please go to Project..Settings..Fortran..Libraries and check the box that says "Use debug C libraries".
Next, the unresolved references appear to be caused by your not including the TCL DLL's import library in your list of libraries to be searched - or just add it to the project.
Steve
katoba88
Steve: I did as suggested and got same error. If I include the ells explicitly in the link,libs settings I get:
Linking...
Start Pass1
libs cl80.dll : fatal error LNK1136: invalid or corrupt file
sara3d.exe - 1 error(I), 0 warning(I)
If I just include the ells in the project I still get:
Searching .libs k80.lib:
Searching .libssend_file. lib:
Searching .libs cl80.lib:
Searching .libssee32.lib:
Done Searching Libraries
LINK : warning LNK4098: default lib "libc.lib" conflicts with use of other libs; use /NODEFAULTLIB:library
End Pass1
xpression.obj : error LNK2001: unresolved external symbol __imp__Tcl_EvalFile@8
xpression.obj : error LNK2001: unresolved external symbol __imp__Tcl_CreateInterp@0
xpression.obj : error LNK2001: unresolved external symbol __imp__Tcl_DeleteInterp@4
DEBUG/sara3d.exe : fatal error LNK1120: 3 unresolved externals
(Note the tcl/tk libs are being searched for unresolved names but not dlls)
I have used the same tcl/tk libs & dlls in a small C program with same code and it works fine. (BTW: I don't include the dlls in the project; just make sure there are available at execution time). I also used dumpbin to look at the tcl dlls and can find missing names.
Any help would be appreciated - I'm probably missing a setting someplace.
Denny Moore
Steven_L_Intel1
If by "ells" you mean the .DLL files, you don't "link against DLLs" and don't put DLLs in the project or link libs options. When a DLL is created, the MS linker also creates a .LIB file called an "export library". THIS is what you need to link against.
If you don't have one, then use the MAKILIB tool to create one from the DLL.
I still think you have a problem with a mixture of debug and non-debug C libraries.
Steve
