Software Archive
Read-only legacy content
17060 Discussions
load Quark BSP firmware symbols
Lee_H_Intel
I am using a derivative of QuarkBSP on my GalileoGen2 board, a Flyswatter2 debugger, and OpenOCD 0.9.0 and Intel System Studio 2015 for Windows.  OpenOCD is running and ISS connects to the GalileoGen2, but I can't figure out how to get my firmware symbols loaded.  Does anyone have advice?
Lee_H_Intel
I found this https://software.intel.com/sites/default/files/managed/7e/ef/03_IntelSystemDebuggerOverview-2015.pdf
and this https://software.intel.com/en-us/articles/intel-system-studio-2014-uefi-bios-debugging
it appears "efi loadthis" is the command to use, just as ITP scripts had "loadthis".  Unfortunately the symbols won't load:
Sukruth_H_Intel
     I anticipate from the INFO line in the screenshot above that the symbol file (.PDB -- in case of windows based compilation) is not found at the path where SecCore.efi is present. Please check it once.
Also if you have the map file, then you can try loading the module directly using "LOADFROMMAP" command as shown below :-
eg: - EFI "LOADMODFROMMAP C:\uefi\SecCore.map SecCore.efi"
Please do let me know if you have any other queries.
Sukruth H V
Lee_H_Intel
SecCore.pdb is present in C:\SSG\Research\lmhamel\MC.combo\Build\Repository\GalileoBoardPkg_B31EB40C-8AFC-409e-BC2B-72264A74311D_0.61\SecCore\SecCore\DEBUG_LOG\Ia32
EFI "LOADMODFROMMAP C:\uefi\SecCore.map SecCore.efi"  (changed path as appropriate) didn't give any output in the Console View.  I don't know if the command succeeded or failed.  I do know my Source Files view still shows nothing, and the Assembler view only shows x86 Assembly code.
Kan_Hayashi
Have you set right path to the symbol file on your host? Otherwise, it's not only problem with SecCore module, but with all modules. You may goto menu bar, click "Options" and choose "Source Directroies...". Then add rule.
Lee_H_Intel
Solution is to copy .efi file to same location as .pdb.
Error message should say: "PDB file found, but .efi file not found in same location".
Why does the code need the .efi file to be in same location as .pdb?  Could the code be fixed to not have this requirement?
Kan_Hayashi
As I replied at IPS -
It's not required to copy the .efi file into the same location as where the .pdb is located, if you created the rule I had provided from my original reply.
In other words, your "solution" (copying the .efi file into the folder where teh .pdb file is located) is not appropriate solution.
Lee_H_Intel
Your solution is correct for a normal build situation.  My solution, not "solution" to imply it's faulty, is the only solution for my build situation.
My suggested fix is to add this text so the user is given clear direction:
Debugger info:
ERROR: Could not locate debug symbols for file: SecCore.efi
INFO: Compile time file location: C:\SSG\Research\lmhamel\MC.combo\...\SecCore.efi
I browsed to the folder above and the .pdb file was there but not the .efi.
This is backwards from the INFO message, which says the .efi file is in the folder but implies it can't find the .pdb file from the ERROR message.
The solution is to add another INFO message that says
INFO: Check the folder to ensure the .efi and .pdb files are in the same location.
