Software Archive
Read-only legacy content
17060 Discussions
massive IDB Debugger crash can't use
bernaske
!SESSION 2011-09-21 13:53:32.940 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_22
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=de_DE
Framework arguments: -gui -native
Command-line arguments: -gui -native
!ENTRY org.eclipse.equinox.registry 2 0 2011-09-21 13:53:37.136
!MESSAGE The extensions and extension-points from the bundle "com.intel.debugger.ui.nl1" are ignored. The bundle is not marked as singleton.
!ENTRY org.eclipse.osgi 2 1 2011-09-21 13:53:37.779
!MESSAGE NLS unused message: ActionManager_deleteBreakpointAll in: com.intel.debugger.ui.messages
!MESSAGE NLS unused message: ActionManager_deleteBreakpointAllDesc in: com.intel.debugger.ui.messages
!MESSAGE NLS unused message: ActionManager_suspendDesc in: com.intel.debugger.ui.messages
!ENTRY org.eclipse.osgi 2 1 2011-09-21 13:53:37.780
!MESSAGE NLS unused message: ActionManager_interruptDesc in: com.intel.debugger.ui.messages
!MESSAGE NLS unused message: ActionManager_openPagingWindow in: com.intel.debugger.ui.messages
!MESSAGE NLS unused message: ActionManager_suspend in: com.intel.debugger.ui.messages
!MESSAGE NLS unused message: ActionManager_interrupt in: com.intel.debugger.ui.messages
!MESSAGE NLS unused message: ActionManager_openAddressTranslationDialog in: com.intel.debugger.ui.messages
!MESSAGE NLS missing message: ActionManager_kill in: com.intel.debugger.ui.messages
!ENTRY org.eclipse.osgi 2 1 2011-09-21 13:53:37.781
!MESSAGE NLS missing message: ActionManager_killDesc in: com.intel.debugger.ui.messages
!MESSAGE NLS missing message: ActionManager_loadBatchFile in: com.intel.debugger.ui.messages
!ENTRY org.eclipse.jface 4 0 2011-09-21 13:53:37.908
!MESSAGE The command ("com.intel.debugger.ui.actions.TDSDEnable") is undefined
!STACK 0
java.lang.Exception
at org.eclipse.jface.action.ExternalActionManager$CommandCallback.isActive(ExternalActionManager.java:370)
at org.eclipse.jface.action.ActionContributionItem.isCommandActive(ActionContributionItem.java:647)
at org.eclipse.jface.action.ActionContributionItem.isVisible(ActionContributionItem.java:703)
at com.intel.debugger.ui.ActionManager$ActionWithContributions.addContribution(Unknown Source)
at com.intel.debugger.ui.ActionManager.createContribution(Unknown Source)
at com.intel.debugger.ui.rcp.ApplicationActionBarAdvisor.fillMenuBar(Unknown Source)
at org.eclipse.ui.application.ActionBarAdvisor.fillActionBars(ActionBarAdvisor.java:150)
at org.eclipse.ui.internal.WorkbenchWindow.fillActionBars(WorkbenchWindow.java:3482)
at org.eclipse.ui.internal.WorkbenchWindow.(WorkbenchWindow.java:404)
at org.eclipse.ui.internal.tweaklets.Workbench3xImplementation.createWorkbenchWindow(Workbench3xImplementation.java:31)
at org.eclipse.ui.internal.Workbench.newWorkbenchWindow(Workbench.java:1731)
at org.eclipse.ui.internal.Workbench.access$14(Workbench.java:1729)
at org.eclipse.ui.internal.Workbench$19.runWithException(Workbench.java:1023)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:134)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3468)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3115)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:803)
at org.eclipse.ui.internal.Workbench$28.runWithException(Workbench.java:1384)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2316)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2221)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:493)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
at com.intel.debugger.ui.rcp.Application.start(Unknown Source)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
!MESSAGE The command ("com.intel.debugger.ui.actions.TDSDStopOnEvent") is undefined
!STACK 0
java.lang.Exception
!MESSAGE The command ("com.intel.debugger.ui.logicwnd.DataSharingEventsWnd") is undefined
!STACK 0
java.lang.Exception
!ENTRY org.eclipse.jface 4 0 2011-09-21 13:53:37.909
!MESSAGE The command ("com.intel.debugger.ui.logicwnd.DataSharingFiltersWnd") is undefined
!STACK 0
java.lang.Exception
!MESSAGE The command ("com.intel.debugger.ui.actions.BreakOnReEntrantCall") is undefined
!STACK 0
java.lang.Exception
!MESSAGE The command ("com.intel.debugger.ui.actions.SerializeParallelRegions") is undefined
!STACK 0
java.lang.Exception
!ENTRY org.eclipse.jface 4 0 2011-09-21 13:53:37.910
!MESSAGE The command ("com.intel.debugger.ui.logicwnd.OpenMPTaskWnd") is undefined
!STACK 0
java.lang.Exception
!MESSAGE The command ("com.intel.debugger.ui.logicwnd.OpenMPSpawnWnd") is undefined
!STACK 0
java.lang.Exception
!ENTRY org.eclipse.jface 4 0 2011-09-21 13:53:37.916
!MESSAGE The command ("com.intel.debugger.ui.logicwnd.SIMDEvalWnd") is undefined
!STACK 0
java.lang.Exception
at com.intel.debugger.ui.rcp.ApplicationActionBarAdvisor.addViewToolbar(Unknown Source)
at com.intel.debugger.ui.rcp.ApplicationActionBarAdvisor.fillCoolBar(Unknown Source)
at org.eclipse.ui.application.ActionBarAdvisor.fillActionBars(ActionBarAdvisor.java:153)
!ENTRY org.eclipse.jface 4 0 2011-09-21 13:53:37.917
!MESSAGE The command ("com.intel.debugger.ui.logicwnd.PagingWnd") is undefined
!STACK 0
java.lang.Exception
!MESSAGE The command ("com.intel.debugger.ui.actions.Dbg.OpenAddressTranslationDialog") is undefined
!STACK 0
java.lang.Exception
!ENTRY org.eclipse.jface 4 0 2011-09-21 13:53:38.644
!MESSAGE The command ("com.intel.debugger.ui.logicwnd.CilkThreadStackWnd") is undefined
!STACK 0
java.lang.Exception
at com.intel.debugger.ui.windows.WindowManager$1.run(Unknown Source)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
Hubert_H_Intel
Looks like this is a duplicate to http://software.intel.com/en-us/forums/showthread.php?t=86480 where I entered an answer.Can we close this thread 86481?
Hubert_H_Intel
I'm closing this thread since it's a duplicate to 86480.
