eclipse.buildId=unknown
java.version=1.6.0_22
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=de_DE
Framework arguments: -gui -native
Command-line arguments: -gui -native
!ENTRY org.eclipse.equinox.registry 2 0 2011-09-21 13:53:37.136
!MESSAGE The extensions and extension-points from the bundle "com.intel.debugger.ui.nl1" are ignored. The bundle is not marked as singleton.
!ENTRY org.eclipse.osgi 2 1 2011-09-21 13:53:37.779
!MESSAGE NLS unused message: ActionManager_deleteBreakpointAll in: com.intel.debugger.ui.messages
!MESSAGE NLS unused message: ActionManager_deleteBreakpointAllDesc in: com.intel.debugger.ui.messages
!MESSAGE NLS unused message: ActionManager_suspendDesc in: com.intel.debugger.ui.messages
!ENTRY org.eclipse.osgi 2 1 2011-09-21 13:53:37.780
!MESSAGE NLS unused message: ActionManager_interruptDesc in: com.intel.debugger.ui.messages
!MESSAGE NLS unused message: ActionManager_openPagingWindow in: com.intel.debugger.ui.messages
!MESSAGE NLS unused message: ActionManager_suspend in: com.intel.debugger.ui.messages
!MESSAGE NLS unused message: ActionManager_interrupt in: com.intel.debugger.ui.messages
!MESSAGE NLS unused message: ActionManager_openAddressTranslationDialog in: com.intel.debugger.ui.messages
!MESSAGE NLS missing message: ActionManager_kill in: com.intel.debugger.ui.messages
!ENTRY org.eclipse.osgi 2 1 2011-09-21 13:53:37.781
!MESSAGE NLS missing message: ActionManager_killDesc in: com.intel.debugger.ui.messages
!MESSAGE NLS missing message: ActionManager_loadBatchFile in: com.intel.debugger.ui.messages
!ENTRY org.eclipse.jface 4 0 2011-09-21 13:53:37.908
!MESSAGE The command ("com.intel.debugger.ui.actions.TDSDEnable") is undefined
!STACK 0
java.lang.Exception
at org.eclipse.jface.action.ExternalActionManager$CommandCallback.isActive(ExternalActionManager.java:370)
at org.eclipse.jface.action.ActionContributionItem.isCommandActive(ActionContributionItem.java:647)
at org.eclipse.jface.action.ActionContributionItem.isVisible(ActionContributionItem.java:703)
at com.intel.debugger.ui.ActionManager$ActionWithContributions.addContribution(Unknown Source)
at com.intel.debugger.ui.ActionManager.createContribution(Unknown Source)
at com.intel.debugger.ui.rcp.ApplicationActionBarAdvisor.fillMenuBar(Unknown Source)
at org.eclipse.ui.application.ActionBarAdvisor.fillActionBars(ActionBarAdvisor.java:150)
at org.eclipse.ui.internal.WorkbenchWindow.fillActionBars(WorkbenchWindow.java:3482)
at org.eclipse.ui.internal.tweaklets.Workbench3xImplementation.createWorkbenchWindow(Workbench3xImplementation.java:31)
at org.eclipse.ui.internal.Workbench.newWorkbenchWindow(Workbench.java:1731)
at org.eclipse.ui.internal.Workbench.access$14(Workbench.java:1729)
at org.eclipse.ui.internal.Workbench$19.runWithException(Workbench.java:1023)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:134)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3468)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3115)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:803)
at org.eclipse.ui.internal.Workbench$28.runWithException(Workbench.java:1384)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2316)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2221)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:493)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
at com.intel.debugger.ui.rcp.Application.start(Unknown Source)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
!MESSAGE The command ("com.intel.debugger.ui.actions.TDSDStopOnEvent") is undefined
!STACK 0
java.lang.Exception
!MESSAGE The command ("com.intel.debugger.ui.logicwnd.DataSharingEventsWnd") is undefined
!STACK 0
java.lang.Exception
!ENTRY org.eclipse.jface 4 0 2011-09-21 13:53:37.909
!MESSAGE The command ("com.intel.debugger.ui.logicwnd.DataSharingFiltersWnd") is undefined
!STACK 0
java.lang.Exception
!MESSAGE The command ("com.intel.debugger.ui.actions.BreakOnReEntrantCall") is undefined
!STACK 0
java.lang.Exception
!MESSAGE The command ("com.intel.debugger.ui.actions.SerializeParallelRegions") is undefined
!STACK 0
java.lang.Exception
!ENTRY org.eclipse.jface 4 0 2011-09-21 13:53:37.910
!MESSAGE The command ("com.intel.debugger.ui.logicwnd.OpenMPTaskWnd") is undefined
!STACK 0
java.lang.Exception
!MESSAGE The command ("com.intel.debugger.ui.logicwnd.OpenMPSpawnWnd") is undefined
!STACK 0
java.lang.Exception
!ENTRY org.eclipse.jface 4 0 2011-09-21 13:53:37.916
!MESSAGE The command ("com.intel.debugger.ui.logicwnd.SIMDEvalWnd") is undefined
!STACK 0
java.lang.Exception
at com.intel.debugger.ui.rcp.ApplicationActionBarAdvisor.addViewToolbar(Unknown Source)
at com.intel.debugger.ui.rcp.ApplicationActionBarAdvisor.fillCoolBar(Unknown Source)
at org.eclipse.ui.application.ActionBarAdvisor.fillActionBars(ActionBarAdvisor.java:153)
!ENTRY org.eclipse.jface 4 0 2011-09-21 13:53:37.917
!MESSAGE The command ("com.intel.debugger.ui.logicwnd.PagingWnd") is undefined
!STACK 0
java.lang.Exception
!MESSAGE The command ("com.intel.debugger.ui.actions.Dbg.OpenAddressTranslationDialog") is undefined
!STACK 0
java.lang.Exception
!ENTRY org.eclipse.jface 4 0 2011-09-21 13:53:38.644
!MESSAGE The command ("com.intel.debugger.ui.logicwnd.CilkThreadStackWnd") is undefined
!STACK 0
java.lang.Exception
at com.intel.debugger.ui.windows.WindowManager$1.run(Unknown Source)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
http://software.intel.com/en-us/forums/showthread.php?t=86480 ?
What's exactly your OS and platform?
Which package did you install (Parallel Studio XE, Composer XE)?
Did you setup the environment correctly such (default):
$ source /opt/intel/bin/compilervars.sh ia32|intel64 ?
What is the debugger version? Run the following after having executed the source script mentioned above:
$ idbc
What exactly is your JRE? Run the following:
$ java -versoin
What does the .gdbinit contain (if existing on your working directory)?
If the source script is invoked correctly and if the JRE is the right one (should match the platform, 32- or 64-bit), then the debugger GUI is just started with:
$ idb
Don't set parameters, exept of the debugee (otpional).
Hubert.
