Software Archive
Read-only legacy content
17060 Discussions
matrix vector Product/iterative solver
hashirkk
Hello all,
I am copying two different codes below for your analysis and help. The first code takes a large Sparse matrix and apply the iterative solution algorithm on that. The second code below, takes the same sparse matrix, apply a simple storage mechanism onto that and convert it into Dense matrix (containing only non-zero values ) and then apply the iterative solver on that matrix to converge.
Problem: If I set the size of the matrix size small i.e. less than 2kx2k, the results of both the code are approximatel same but for large matrices > 2k, the results of both the code donot match at all.
Note: matrix is a penta-diagonal matrix.
I would really appreciate if somebody can guide me what mistake Am I making or is there any problem in the second code Algorithm.
Code #1:
Generation of a penta-diagonal sparse matrix (A).
for (i = 0; i < ROWS; i++) {
c = 0.0;
for (j = 0; j < COLS; j++)
if (j==i)
if (i==0 && j==0)
matrixj+1 = (float) 1.0;
matrix = (float) 2.0;
matrixj+GRID_SIZE = (float) 3.0;
if (i == ROWS-1)
matrixj-1 = (float) 1.0;
matrix = (float) 4.0;
matrixj-GRID_SIZE = (float) 3.0;
else
if (i % GRID_SIZE == 0 )
else
if ((i+1)%GRID_SIZE !=0)
if ((j+GRID_SIZE)<= COLS)
if ((j-GRID_SIZE)>= 0)
} // j == i
} // j
} //i
// Generation of dummy constant vector (b)
b[0] = 3; b[1]= 1; b[2] = 1;b[3] = 1; b[4]= 1; b[5] = 1;b[6] = 1; b[7]= 1; b[8] = 1;
for (i=9;ib = b[8];
// Start of Iterative Solver
for (it = 0; it < ROWS; it++) {
matrix_vector_product (matrix, x, g,ROWS);
matrix_vector_product (matrix, d, tmpvec,ROWS);
} // end of loop
//Matrix Vector product Code.
void matrix_vector_product (float **a, float *b, float *c,int ROWS)
int i, j;
int N = ROWS;
float tmp;
for (i = 0; i < N; i++) {
tmp = 0.0;
for (j = 0; j < N; j++)
tmp += a * b;
c = tmp;
Code #2: Converting sparse matrix to Dense matrix for effecient Data storage
c = 0.0;
if (j==i)
if (i==0 && j==0)
if (i == ROWS-1)
else
else
} // j == i
} // j
} //i
// Additional steps to conver the sparse matrix to dense matrix ROWS*DIAGONALS+1 and storing of indices in seperate matrix
k = 0;
if (matrix != 0.0)
matrix_min = matrix;
// changes made for the penta_diagonal matrix.The index array
// will contain the value of the vector j to which the matrix
// needs to be multiplied.
index = j;
k++;
for (i=9;ib = b[8];
min_matrix_vector_product (matrix_min,index, x, g,ROWS);
min_matrix_vector_product (matrix_min, index,d, tmpvec,ROWS);
} // end of loop
//Matrix Vector product Code (modified for Dense matrix.
void min_matrix_vector_product (float **a, int **d,float *b, float *c,int ROWS)
int i, j;
int N = ROWS;
float tmp;
tmp = 0.0;
for (j = 0; j < DIAGONALS+1; j++){
tmp += a * b[dj];
c = tmp;
hashirkk
Can please somebody help me with the above code problem? Let me know if the question or the pasted code is not clear
Quoting - hashirkk
Hello all,
Code #1:
c = 0.0;
if (j==i)
if (i==0 && j==0)
if (i == ROWS-1)
else
else
} // j == i
} // j
} //i
for (i=9;ib = b[8];
} // end of loop
int i, j;
int N = ROWS;
float tmp;
tmp = 0.0;
tmp += a * b;
c = tmp;
c = 0.0;
if (j==i)
if (i==0 && j==0)
if (i == ROWS-1)
else
else
} // j == i
} // j
} //i
k = 0;
if (matrix != 0.0)
index = j;
k++;
for (i=9;ib = b[8];
} // end of loop
int i, j;
int N = ROWS;
float tmp;
tmp = 0.0;
tmp += a * b[dj];
c = tmp;
