Software Archive
Read-only legacy content
micctrl crash
Kazutomo_Y_
micctrl crashes if I change OSimage in micX.conf on MPSS 3.2. I traced it and found a problem.   I checked the MPSS-3.2.1 source code and looks this problem still there. See below for a fix.
- kaz
--- mpss-daemon-3.2/libmpssconfig/mpssconfig.c.bak    2014-04-24 01:01:47.097544049 -0500
+++ mpss-daemon-3.2/libmpssconfig/mpssconfig.c    2014-04-24 01:02:01.256545552 -0500
@@ -205,7 +205,7 @@
         return 0;
-    if ((mic->config.boot.systemmap = malloc(strlen(map)) + 1) != NULL) {
+    if ((mic->config.boot.systemmap = malloc(strlen(map)+ 1)) != NULL) {
         strcpy(mic->config.boot.systemmap, map);
         add_perr(perrs, PINFO, "%s: [Parse] OS System map %s", mic->name, map);
Loc_N_Intel
Hi Kazutomo,
I tried to reproduce the problem you reported but I didn't see it. Here is what I did on my system with MPSS 3.2.1 (note that bzImage-2.6.38+mpss3.2-knightscorner and System.map-2.6.38+mpss3.2-kgnightscorner are currently existing files under /usr/share/mpss/boot)
% micinfo
% cd /usr/share/mpss/boot
% cp bzImage-2.6.38+mpss3.2-knightscorner bzImage-test
% micctrl --osimage=/usr/share/mpss/boot/bzImage-test --sysmap=/usr/share/mpss/boot/System.map-knightscorner mic0
% service mpss stop
% service mpss start
MPSS comes up properly, mic0 booted with bzImage-test.
Would you like to describe how did you find the issue? Thank you.
Kazutomo_Y_
Hi Loc-nguyen,
The code probably works without segv by luck. It depends on the string length (technically of the system map).
Please take a look at the source code of  mpss-daemon-3.2/libmpssconfig/mpssconfig.c  The line number 208 in a copy of the mpss source code I have
This malloac only allocates the size strlen(map) and adds 1 to the malloc result.  The following strcpy is likely to trigger a data corruption.
- kaz
Loc_N_Intel
Hi Kazutomo,
I also tried with sysmap in micctrl but still couldn't reproduce the problem. However, I agree the code needs to be changed. I did file a bug report, (ID: 4868934) to report this issue..
Thank you..
