Software Archive
Read-only legacy content
17061 Discussions
micprun and compilervars.sh
Etienne_S_
Dear all,
I just buit a new xeon phi test host. I would like to run the micprun stress test program, but when I run it, it fails because it cannot find the compilervars.sh script.
I downloaded and installed the run-time from here:
https://software.intel.com/en-us/articles/redistributables-for-intel-parallel-studio-xe-2016-composer-edition-for-linux
The installation folder was /home/user, which resulted in the scripts placed in /home/user/bin, which I added to the bash PATH. I can run the script "compilervars.sh intel64" manually, but the micprun command says these cannot be found. What is the issue there?
Etienne
JJK
New Contributor III
which env vars are set after sourcing the /home/user/bin/compilervars.sh script? you should see many env vars starting with MIC_ etc ; if not, then the PROD_DIR env var inside the compilervars.sh script needs to be adjusted - it is hardcoded to point to /opt/intel/composer_xe_2016 (or something similar).
HTH,
JJK
Etienne_S_
I just forgot to use "source" and ran the script directly... Thanks!
