Software Archive
Read-only legacy content
17060 Discussions
micsmc and QGtkStyle problem
j0e
Recently, after some updates no doubt, when I try to start up micsmc, it briefly does, but then quickly issues this error and closes:
QGtkStyle was unable to detect the current GTK+ theme.
terminate called after throwing an instance of 'mic_exception'
  what():  std::exception
micctrl --config gives
mic0:
    Config Version: 1.1
    Linux Kernel:   /usr/share/mpss/boot/bzImage-knightscorner
    Map File:       /usr/share/mpss/boot/System.map-knightscorner
    BootOnStart:    Enabled
    Shutdowntimeout: 300 seconds
    ExtraCommandLine: highres=off
    PowerManagment: cpufreq_on;corec6_off;pc3_on;pc6_off
    Root Device:   Dynamic Ram Filesystem /var/mpss/mic0.image.gz from:
	Base:      CPIO /usr/share/mpss/boot/initramfs-knightscorner.cpio.gz
	Overlay:   Filelist /var/mpss/sep /var/mpss/sep/sep4.1/sep.filelist on
	Overlay:   Filelist /var/mpss//amplxe/vtune_amplifier_xe_2017.4.0.518798 /var/mpss//amplxe/vtune_amplifier_xe_2017.4.0.518798/itt.filelist on
	Overlay:   Filelist /var/mpss//amplxe/vtune_amplifier_xe_2017.4.0.518798 /var/mpss//amplxe/vtune_amplifier_xe_2017.4.0.518798/amplxe.filelist on
	CommonDir: Directory /var/mpss/common
	Micdir:    Directory /var/mpss/mic0
    Network:       Static bridge br0
        MIC IP:    10.10.10.1
        Host IP:   10.10.10.254
        Net Bits:  24
        NetMask:   255.255.255.0
        MtuSize:   64512
        Hostname:  axial-mic0
        MIC MAC:   4c:79:ba:2a:06:4c
        Host MAC:  4c:79:ba:2a:06:4d
    LDAP:          Disabled
     NIS:          Disabled
    Cgroup:
        Memory:    Disabled
    Console:        hvc0
    VerboseLogging: Disabled
    CrashDump:      /var/crash/mic 16GB
I'm running CentOS Linux release 7.3.1611,  I assume this is a linux problem I need to solve, but it does mention the mic_exception.  Although I have frozen kernel updates, other system components are updated from time to time.  It would be nice if the MPSS would allow kernel updates without have to reinstall MPSS.
Thanks for any help?
