Software Archive
Read-only legacy content
more threads will decrease the performance on phi
ye_f_1
hi, I run a big program on cpu and phi in symmetrical mode.But I find more thread will decrease performance on phi.The structure of program is very simple.The following content is the outline of program. #define move_threads 57 #define compute_threads 57 int a[1000000]; // a big array int compute_count[compute_threads]; inline void * move() { } inline void * status_count(){ } inline void *compute(void * arg){ int * id=(int *)arg; int count=0; for(int i=*id;i<1000000;i+=compute_threads){ count+=a; } compute_count[*id]=count; return (void *)0; } int main(){ for(int it=0;i<20;i++){ .............. for(.........){ pthread_create(&move_tid,NULL,move,NULL); } ............. for(int i=0;i
ye_f_1
hi,
    int count=0;
        count+=a;
    return (void *)0;
int
main(){
    for(.........){
    for(int i=0;i<move_threads;i++){
        pthread_join(move_tid,NULL);
    for(int i=0;i<coumpute_threads;i++){
        id=i;
        pthread_create(&compute_tid,NULL,compute,&id);
    double before_compute=rtclock();
        pthread_join(compute_tid,NULL);
    double after_compute=rtclock();
    double t_compute=after_compute-before_compute;
    total_compute+=    t_compute;
  cout<<total_compute<<endl;
These are many functions like compute and move in program.In first time,compute_threads is set as 18,I find the result of total_compute is 0.0100641 second.In second time, compute_threads is set as 57, the result of total_compute is 0.0289173 second.In third time,compute_threads is equal to 114,the total_compute is 0.0645232 second.In fourth time.compute_threads is equal to 228,the total_compute is 0.11988 second.
It is seems that more threads will decrease the  performance on phi.What's wrong ?
I clear all the functions except compute.In this circumstance,more threads will increase.
By the way,There are 57 cores in my phi.
ye_f_1
hi,
    int count=0;
        count+=a;
    return (void *)0;
int
main(){
    for(.........){
        id=i;
Gregg_S_Intel
Is rtclock() measuring elapsed time or CPU time?
ye_f_1
rtclock() measuring elapsed time.
#include "util.h"
#include <stdio.h>
#include <sys/time.h>
double rtclock() {
        struct timezone Tzp;
        struct timeval Tp;
        int stat;
        stat = gettimeofday (&Tp, &Tzp);
        if (stat != 0) printf("Error return from gettimeofday: %d",stat);
        return(Tp.tv_sec + Tp.tv_usec*1.0e-6);
McCalpinJohn
It is easy for more threads to reduce overall performance...
Three common cases are:
  1. The overhead of parallel synchronization constructs increases with thread count, so if the amount of work per synchronization is too small, total execution time can increase.
  2. Running more than one thread per physical core will result in less effective cache capacity per thread.  This can increase the overall cache miss rate and the overall memory traffic and thereby increase execution time.
  3. Running more than one thread per physical core will increase the number of memory access streams.  If the number of memory access streams exceed the number of DRAM banks, bank conflict rates will increase.  This leads to more DRAM stall cycles and (if ECC is enabled) to more DRAM reads/writes for the ECC data, again leading to increased execution time.
jimdempseyatthecove
Your runtime is very short, each time you issue pthread_create/pthread_join you encounter some overhead. It is much better to use one of the thread pooling paradigms (OpenMP, TBB, Cilk++, ...).
Also, your code is not using any affinity pinning (available with OpenMP via environment variables, by API with the others).
     int count=0;
         count+=a;
     return (void *)0;
int main()
   const int repCount = 20;
   double iteration_compute_time[repCount];
   for(int it=0;i<repCount;i++){
     #pragma omp parallel for num_threads(move_threads) schedule(static,1)
        move();
     } // implicit barrier here
    double before_compute=rtclock(); // you had this placed in the wrong location
    #pragma omp parallel for num_threads(compute_threads) schedule(static,1)
         id=i;
         compute(&id);
     iteration_compute_time=after_compute-before_compute;
     total_compute+=    iteration_compute_time;
   for(int i=0;i<repCount;i++){
     cout<<iteration_compute_time<<endl;
The above is untested code.
The above assumes all the moves are performed independently (and completely) of the compute. You might find it beneficial to have the move_threads == compute_threads (always), then setup the move section (portioning of data) the same as the compute section. Assuming there is not temporal dependencies between partitions. This way you can use one #pragma omp parallel region with each thread performing a move of a section followed by a compute. In this manner, you can construct the partitions, such that each partition data usage fits within L1 cache and the number of partitions is independent from the number of threads. (the above has the partition size inversely proportional to the number of threads).
Jim Dempsey
ye_f_1
Hi,Jim
    I change pthread to openmp and set KMP_AFFINITY=scatter.But I find the same problem.
    compute_threads       total_compute
        18                         0.00459003
        57                         0.00944662
        114                       0.0506935
        228                       0.234504
jimdempseyatthecove
Try performing some actual work:
const int size_a = 1000000;
int a[size_a];  // a big array
  for(int i=0;i<size_a;++i){
    a = i&15+2; // some number between 2 and 17
// Serial recursive method to calculate Fibonacci series
// do not inline this (cannot be inlined because it is a recursive function)
int SerialFib( int n )
 if( n<2 )
  return n;
 else
  return SerialFib(n-1)+SerialFib(n-2);
     int count=0;
     for(int i=*id;i<size_a;i+=compute_threads){
         count+=a; // sum of (some number between 2 and 17)
         // perform some actual work
         a = SerialFib(a);
     return (void *)0;
int main()
        move();  // re-initialize array a
         id=i;
         compute(&id);
The above is untested.
Jim Dempsey
jimdempseyatthecove
ye,
My post #9 is not correct. My intention was to have your compute function perform significantly more computation than memory R/W. Unfortunately, the recursive SerialFib is mostely memory I/O (pushing return address/popping return address).
Replace the SerialFib function with something that does some computation.
Also, bear in mind the strongest feature of the Xeon Phi is its wide vectors. See if you can construct a representative computation section that is both computationally intensive (without a lot of non-cachable memory references) and is amenable to vectorization.
Jim Demspey
