Software Archive
Read-only legacy content
17060 Discussions
mpiicc architecture incompatibility on Xeon Phi x200 KNL
Simone_Tinti
i receive the following errors while trying to compile High Performance Linpack for Intel Xeon Phi x200 (KNL), do you have any suggestion?
mpiicc -o HPL_pdtest.o -c  -DHPL_CALL_CBLAS -I/opt/hpl-2.2/include -I/opt/hpl-2.2/include/KNL_MKL5 -I/opt/intel/compilers_and_libraries/linux/mkl/include/mic/lp64 -I/opt/intel/impi/2017.2.174/mic/include -xHost -fomit-frame-pointer -O3 -funroll-loops -qopenmp  ../HPL_pdtest.c
mpiicc  -DHPL_CALL_CBLAS -I/opt/hpl-2.2/include -I/opt/hpl-2.2/include/KNL_MKL5 -I/opt/intel/compilers_and_libraries/linux/mkl/include/mic/lp64 -I/opt/intel/impi/2017.2.174/mic/include -xHost -fomit-frame-pointer -O3 -funroll-loops -qopenmp -o /opt/hpl-2.2/bin/KNL_MKL5/xhpl HPL_pddriver.o         HPL_pdinfo.o           HPL_pdtest.o /opt/hpl-2.2/lib/KNL_MKL5/libhpl.a  -Wl,--start-group /opt/intel/compilers_and_libraries/linux/mkl/lib/mic/libmkl_intel_lp64.a /opt/intel/compilers_and_libraries/linux/mkl/lib/mic/libmkl_intel_thread.a /opt/intel/compilers_and_libraries/linux/mkl/lib/mic/libmkl_core.a -Wl,--end-group -lpthread -lm /opt/intel/impi/2017.2.174/mic/lib/libmpi_mt.a
ld: k1om architecture of input file `/opt/intel/compilers_and_libraries/linux/mkl/lib/mic/libmkl_intel_lp64.a(cblas_idamax_lp64.o)' is incompatible with i386:x86-64 output
ld: k1om architecture of input file `/opt/intel/compilers_and_libraries/linux/mkl/lib/mic/libmkl_intel_lp64.a(cblas_dtrsv_lp64.o)' is incompatible with i386:x86-64 output
ld: k1om architecture of input file `/opt/intel/compilers_and_libraries/linux/mkl/lib/mic/libmkl_intel_lp64.a(cblas_dtrsm_lp64.o)' is incompatible with i386:x86-64 output
ld: k1om architecture of input file `/opt/intel/compilers_and_libraries/linux/mkl/lib/mic/libmkl_intel_lp64.a(cblas_dscal_lp64.o)' is incompatible with i386:x86-64 output
ld: k1om architecture of input file `/opt/intel/compilers_and_libraries/linux/mkl/lib/mic/libmkl_intel_lp64.a(cblas_dger_lp64.o)' is incompatible with i386:x86-64 output
ld: k1om architecture of input file `/opt/intel/compilers_and_libraries/linux/mkl/lib/mic/libmkl_intel_lp64.a(cblas_dgemv_lp64.o)' is incompatible with i386:x86-64 output
ld: k1om architecture of input file `/opt/intel/compilers_and_libraries/linux/mkl/lib/mic/libmkl_intel_lp64.a(cblas_dgemm_lp64.o)' is incompatible with i386:x86-64 output
source /opt/intel/impi/2017.2.174/bin64/mpivars.sh
source /opt/intel/bin/iccvars.sh intel64
source /opt/intel/bin/ifortvars.sh intel64
source /opt/intel/compilers_and_libraries_2017.2.174/linux/mkl/bin/mklvars.sh  intel64
echo $LD_LIBRARY_PATH
/opt/intel/compilers_and_libraries_2017.2.174/linux/compiler/lib/intel64_lin:/opt/intel/compilers_and_libraries_2017.2.174/linux/mkl/lib/intel64_lin:/opt/intel/compilers_and_libraries_2017.2.174/linux/compiler/lib/intel64:/opt/intel/compilers_and_libraries_2017.2.174/linux/compiler/lib/intel64_lin:/opt/intel/compilers_and_libraries_2017.2.174/linux/mpi/intel64/lib:/opt/intel/compilers_and_libraries_2017.2.174/linux/mpi/mic/lib:/opt/intel/compilers_and_libraries_2017.2.174/linux/ipp/lib/intel64:/opt/intel/compilers_and_libraries_2017.2.174/linux/compiler/lib/intel64_lin:/opt/intel/compilers_and_libraries_2017.2.174/linux/mkl/lib/intel64_lin:/opt/intel/compilers_and_libraries_2017.2.174/linux/tbb/lib/intel64/gcc4.7:/opt/intel/debugger_2017/iga/lib:/opt/intel/debugger_2017/libipt/intel64/lib:/opt/intel/compilers_and_libraries_2017.2.174/linux/daal/lib/intel64_lin:/opt/intel/compilers_and_libraries_2017.2.174/linux/compiler/lib/intel64:/opt/intel/compilers_and_libraries_2017.2.174/linux/compiler/lib/intel64_lin:/opt/intel/compilers_and_libraries_2017.2.174/linux/mpi/intel64/lib:/opt/intel/compilers_and_libraries_2017.2.174/linux/mpi/mic/lib:/opt/intel/compilers_and_libraries_2017.2.174/linux/ipp/lib/intel64:/opt/intel/compilers_and_libraries_2017.2.174/linux/compiler/lib/intel64_lin:/opt/intel/compilers_and_libraries_2017.2.174/linux/mkl/lib/intel64_lin:/opt/intel/compilers_and_libraries_2017.2.174/linux/tbb/lib/intel64/gcc4.7:/opt/intel/debugger_2017/iga/lib:/opt/intel/debugger_2017/libipt/intel64/lib:/opt/intel/compilers_and_libraries_2017.2.174/linux/daal/lib/intel64_lin:/opt/intel/compilers_and_libraries_2017.2.174/linux/daal/../tbb/lib/intel64_lin/gcc4.4:/opt/intel/compilers_and_libraries_2017.2.174/linux/mpi/intel64/lib:/opt/intel/compilers_and_libraries_2017.2.174/linux/mpi/mic/lib
NOTES:
-same errors using different options like -x MIC-AVX512
-from documentation it's not clear to me if for x200 Xeon Phi the  lib and include files  shuold be the ones in /intel64 o /mic subfolders (that anyway seem to be selected automatically (mic version) at compile time  despite of  he LD_LIBRARY_PATH directories order)
Many thanks for your support
Simone Tinti
TimP
No, you must permit the linker to use the intel64 mkl libraries, not the ones which support only knc.
Simone_Tinti
Many thanks for you support, setting LD_LIBRARY_PATH properly solved this issue.
Simone.
