Software Archive
Read-only legacy content
mpss support for Red Hat Enterprise Linux 7
Anwar_L_
I am planning on upgrading to RHEL 7. Is there a target date for supporting mpss on RHEL 7?
Otherwise would it be possible to have an early access to mpss for RHEL 7?
Loc_N_Intel
Hi Anwar,
The next release of MPSS (3.3) will support RHEL 7.0 . This should happen very soon, please stay tuned. Thank you.
Anwar_L_
Greats news! Looking forwards to this. Thanks.
Cmd_default_Cmd_defa
Ok- mpss-3.3 outed. I don't see any support for rhel7 ?
July 14, 2014: Intel® MPSS 3.3 released for Linux and Windows
https://software.intel.com/en-us/articles/intel-manycore-platform-software-stack-mpss
Loc_N_Intel
MPSS 3.3 has support for RHEL 7.0 . You just need to download mpss-3.3-linux.tar and follow the instructions in Section 2.2 of the document readme.txt . Thank you.
Anwar_Ludin
@loc-nguyen:
Updated my new RHEL 7.0 workstation with mpss 3.3. Everything works fine except when I try to update the flash as explained in step 2.4 of readme.txt:
sudo /usr/bin/micflash -update -device all -smcbootloader
No image path specified - Searching: /usr/share/mpss/flash
mic0: Flash image: /usr/share/mpss/flash/EXT_HP2_C0_0390-02.rom.smc
micflash: mic0: No compatible SMC boot-loader image found
Anwar
Loc_N_Intel
In the readme file it said: "If using C0 stepping,  or 5110P B1 SKUs with a TA of G65758-253 or higher, or if the SMC boot loader version is 1.8, ........"
In your case, since your coprocessor is C0 stepping, you just use this command instead:
Thank you.
Anwar_Ludin
@loc-nguyen, thanks that worked!
Anwar
