I am new to programming with MIC cards. I am trying to run a very simple program but it appears that it is taking a long time to offload the data over to the MIC card and also the final output seems to be incorrect, can anyone help me figure out my mistake, please.
#include <iostream>
#include <memory>
#include "omp.h"
#include <malloc.h>
using namespace std;
int main()
int xx=100000;
int yy=10000;
unsigned long long size = xx*yy;
cout << " Simulate Data" << endl;
cout << "data size " << size*4 << endl;
int* aa = (int*) malloc(sizeof(int)*size);
for(unsigned long long ii=0; ii < xx*yy; ++ii)
aa[ii] =1;
cout << " start offload " << endl;
unsigned long long dim = xx*yy;
#pragma offload target(mic:0) \
in(aa:length(dim))
#pragma omp parallel for
for (unsigned long long ii; ii < xx*yy; ++ii)
aa[ii] *= 2;
cout << " offload end " << endl;
cout << " Result " << aa[10] <<" " << aa[1000] << endl;
free(aa);
return 0;
Thank you
Sincerely,
AM
You want to use
inout(aa:length(dim))
Note, the first offload has the overhead of transferring the code and initializing the MIC's OpenMP thread pool. Try:
for(int I=0; I<4; ++I) {
double t0 = omp_get_wtime();
in(aa:length(dim))
aa[ii] *= 2;
double t1 = omp_get_wtime();
cout << " offload end " << t1 - t0 << endl;
} // for
Jim Dempsey
Thank you very much for your prompt reply Jim. I really appreciate all your help. Now, my program is running correctly however the offload is still too slow.
Please note that the code within your offloaded section is trivial.
Read (vector), multiply (vector), write (vector)
That is all it is doing (other than a little loop overhead)
Your offload code should be performing more work to recover the time to pass the data into and out of the MIC.
Choose something like a textbook matrix multiply as a sample code.
Jim Dempsey
