Software Archive
Read-only legacy content
17060 Discussions
no select text when using appframework 3.0
julius_c_
Hi! Im having issues with the select text in the content when appframework is added on the header. I was unable to highlight each content on the app. i ve already changed the user-select stuff from css but no luck. It works on other frameworks like bootstrap, jquery mobile but not with appframework. Any ideas please? Thank you
Chris_P_Intel
If I had to guess, I'd guess it's just a CSS precedence issue, or perhaps a default event handler.
But I'm not quite sure what it is you are trying to do. Could you better describe it, and how you are approaching? Are you trying to use Javascript to select something? Or CSS?
