Software Archive
Read-only legacy content
17060 Discussions
non-advancing output
reinerb
I'm trying to do non-advancing output from a FORTRAN program (console application) on my terminal (screen). The standard write options for non-advancing output work on files, but not on my terminal. Did anybody solve this already?
Reiner
james1
What exactly are you trying to accomplish, and on what platform(s)?
James
reinerb
attached is a sample program which shows my problem. I want to have the output always in the same line, with only the number changing. As it is now, every WRITE statements creates a new line on the screen.
I'm working with Windows 2000 on a Intel P4 system, using Visual Fortran 6.6.
  program nonadvancing
  integer i,j,jj,jjj,ipercent
  jj = 10000000
  do i = 1,100  ! loop
      do j = 1,jj
         jjj = j + i
     end do
     ipercent = jjj - jj
     WRITE(*,'(a,i4,a)') '+ ',ipercent,'% executed '
  end do
  end program nonadvancing
You're not using nonadvancing I/O - that would be if you did a WRITE with ADVANCE='NO' in the control list.
What you have here is Fortran carriage control. The default carriage control interpretation is 'LIST', so the '+' is just another character. You need to have the unit opened with CARRIAGECONTROL='FORTRAN'. Since you are using unit *, the only way to do that is to compile with the option /ccdefault:fortran (this is also under Project..Settings..Fortran..Run-Time Behavior, I think.)
Steve
reinerb
Thanks, Steve!
This was the right tip. Just adding the '/ccdefault:fortran' option under "Project .. Settings .. Fortran" solves the problem. There is no need to use the ADVANCE='no' specifier, in fact it is not accepted to add it in the WRITE statement in this context (compiler error).
Thanks again, Reiner
