Software Archive
Read-only legacy content
17060 Discussions
obvious memory errors not detected
collider
Hi, i use parallel studio 2011 inspector in memory checker mode. I write a small test
double *pointer=new double[20];
delete []pointer;
but my memory checker dose not see any leaks! i configure my compiler like here
http://software.intel.com/en-us/articles/compiler-settings-for-memory-error-analysis-in-intel-parallel-inspector/
But its still not workong!
Vladimir_T_Intel
Could you please share your project?
If needed, I can convert this forum thread to a private in order to exchange confidential information and source codes.
collider
Sure, i can do itpublic - this project just an win32 console project with those 3 strings. But if you want to see a settings, can you say me how i can share this project in vs 2010? Just add all files?
Vladimir_T_Intel
Zip the project and attach to this thread ('Add Files' in the control pane of the editor)
collider
Funny, looks like it was my mistake. I write cin>>i; in the end of programm for waiting and always close it by clicking "close" so in this case of terminate inspector not working correct, but if i let programm close itself everything is fine!
Vladimir_T_Intel
This is the intended behaviour of the Inspector. An application should exit in a "normal way", i.e. without termination.
