Software Archive
Read-only legacy content
17060 Discussions
offload error: process on the device 0 was terminated by signal 11 (SIGSEGV)
zhou
Hi!
I have tried to use tree threads for CPU and MIC cooperation.
But there is error "offload error: process on the device 0 was terminated by signal 11 (SIGSEGV)"
The compile operation is "ifort mic.f90 -mkl -openmp". The codes are as follow:
program mic
use mic_lib
use omp_lib
implicit none
integer::mics,idx
DOUBLE PRECISION,allocatable::A(:)
DOUBLE PRECISION,allocatable::B(:)
DOUBLE PRECISION,allocatable::C(:)
allocate(A(256*256))
allocate(B(256*256))
allocate(C(256*256))
mics = offload_number_of_devices()
!dir$ attributes offload:mic :: DGEMM
!$OMP PARALLEL PRIVATE(idx) NUM_THREADS(mics+1)
!$OMP DO SCHEDULE (static)
do idx=0,mics
if(idx==mics) then
CALL DGEMM('N','N',256,256,256,1.d0,A,256,B,256,0.d0,C,256)
else
!dir$ offload target(mic:idx) in(A,B:length(256*256)) out(C:length(256*256))
end if
end do
!$OMP END DO
!$OMP END PARALLEL
deallocate(A)
deallocate(B)
deallocate(C)
end program mic
zhou
TaylorIoTKidd
One of our experts looked at your problem.
He believes that this may be a bug and has submitted a bug report.
As experts are want to do, he made some recommendations as well: The threads may overwrite each other when they write back to the host; and it is a good idea to initialize your data when you allocate it. None of these will cause the issue you observe.
Taylor
Dave_O_
I have exactly the same error. How do I fix it?
Kevin_D_Intel
In the case cited in the original post the compiler mishandles the constants (256, 0.d0, 1.d0) for the offload region treating them as read-write variables instead of read-only. That leads to the seg-fault when exiting from the offload region trying to write their values back to the host.
The issue is expected to be fixed in the coming Update 3 later this month. To work around you would unfortunately need to define variables to pass in the constants, but do not declare with parameter as those are disallowed in IN/OUT/INOUT. Something like this enables the case to run successfully:
integer :: size=256
double precision:: zero_Dbl=0.d0
double precision:: one_Dbl=1.d0
Martyn_C_Intel
The 14.0 update 3 compiler (14.0.3.174) containing the fix has now been posted and is available for download from the Intel registration center.
zhou
Thanks very much for all of your replies.
The code can implement well on our system now.
