Software Archive
Read-only legacy content
17060 Discussions
passing strings to Visual C++ .dll
Intel_C_Intel
I'm trying to pass a string to a routine in a C++ .dll, have the .dll change the string and then pass it back. I can pass integers by reference fine, but I can't get the strings to work. I have looked at the examples in the Compaq Visual Fortran Programmers Guide. Here is my Fortran code:
interface
subroutine c_routine(int_arg,
& strErrorMessage,
& strInputFile,
& dEndMomentArray) !
!dec$ attributes c::c_routine
!dec$ attributes dllimport::c_routine
integer*4 int_arg
real*8 dEndMomentArray(13,2)
character*(*) strInputFile
character*(*) strErrorMessage
!dec$ attributes reference::int_arg
!dec$ attributes reference::strInputFile
!dec$ attributes reference::strErrorMessage
!dec$ attributes reference::dEndMomentArray
end subroutine c_routine
end interface
character*256 strInputFile
character(256) strErrorMessage
data strErrorMessage /'�'C/
integer*4 int_arg
do i = 1,13
do j = 1,2
dEndMomentArray(i,j) = 0.0
end do
end do
int_arg = 0
!call c_routine.
strInputFile = XMLInputFile
call c_routine(int_arg,
& strErrorMessage,
& strInputFile,
& dEndMomentArray)
This is the simple C++ .dll that it calls:
void c_routine(int& int_arg,
char* cErrorMessage,
char* cInputFile,
double dResults[13][2])
string strInputFile(cInputFile);
cout << cInputFile;
cErrorMessage = "No Error!";
for(long i = 0;i<13;i++)
for(long j = 0;j<2;j++)
dResults = i+j;
int_arg = 50;
The C++ routine can see and change the contents of the strings passed in OK, but it doesn't pass the changed values back to Fortran. Do you have any ideas what I am missing? Thanks.
Intel_C_Intel
I figured out my error. I was filling the string incorrectly in the C++ code. I needed to fill the character string in a loop or using the strcpy function.
Jugoslav_Dujic
Valued Contributor II
Apart from that -- I'm quite tired so I may be wrong -- C declaration
dResults[13][2] looks suspicious to me. C and fortran use different conventions for storing multi-dimensional arrays in memory (or for matrix notation, depending on the viewpoint -- row-major
vs. column-major order). I think that it should be [2][13] and
that it should be instead of . No access violation occurs in your code because everything happens in 26-word space and the i+j operation
is commutative, but for a different expression you'll get wrong results.
Jugoslav
Intel_C_Intel
You are right about the way Fortran and C++ index multi-dimensioned arrays. I didn't do a very thorough check of the results being passed back in the array, so I missed that problem. Thanks, that would have given me a big headache down the road.
Mark
