Software Archive
Read-only legacy content
17060 Discussions
pin tools forum
Olaf_Krzikalla
since Pin Tools belongs to Intel I wonder if there is a forum about it (the Yahoo group is no alternative)?
I encountered some strange behavior in Pin and need to ask someone whether it's a bug or something else.
Best regards
Aubrey_W_
Hi Olaf,
Sorry for the delayed response. Please feel free to post your concerns here, and I'll see if we can get some answers for you.
Aubrey W.
Intel Software Network Support
Olaf_Krzikalla
Hi Aubrey,
nevertheless thank you for the response and the invitation. I'll just use this thread to describe my problem.
I have two versions of a pintool tracing memory refernces of a particular function given by name.
V1:
// -------------------------------------------- start
static int InFunctionOfInterest = 0;
VOID EnterFunction()
++InFunctionOfInterest;
VOID LeaveFunction()
--InFunctionOfInterest;
VOID Instruction(INS ins, VOID *v)
if (InFunctionOfInterest == 0)
return;
// tracing done as in ManualExamples/pinatrace.cpp
VOID Routine(RTN rtn, VOID *v)
if (RTN_Name(rtn) == function_name)
RTN_Open(rtn);
RTN_InsertCall(rtn, IPOINT_BEFORE, (AFUNPTR)EnterFunction, IARG_END);
RTN_InsertCall(rtn, IPOINT_AFTER, (AFUNPTR)LeaveFunction, IARG_END);
RTN_Close(rtn);
int main(int argc, char *argv[])
// init
RTN_AddInstrumentFunction(Routine, 0);
INS_AddInstrumentFunction(Instruction, 0);
// aso.
// -------------------------------------------- stop
and V2:
if (RTN_Name(rtn) == functionName)
RTN_Open(rtn);
for (INS ins = RTN_InsHead(rtn); INS_Valid(ins); ins = INS_Next(ins))
Instruction(ins, 0);
RTN_Close(rtn);
// init
// not needed: INS_AddInstrumentFunction(Instruction, 0);
// aso.
Now V1 has the clear advantage over V2 that it traces the function recursively. For V2 I haven't found a way to recursively instrument the instructions by hand (something like a function "RTN INS_GetCallee(INS)" could be handy).
However V1 shows strange behavior when a function is traced. In particular the first traces are somehow left out. That is, either "EnterFunction" gets called too late or the first couple of instructions of a function aren't instrumented properly.
For the moment I can live with V2 but eventually I'd like to get V1 working properly. And I'm not sure if it's my fault or if it's due to some quirks in Pintools.
Thanks in advance
Olaf
MarkC_Intel
Please join the pinheads Yahoo group and ask this question there.
Olaf_Krzikalla
Sorry to say so, but no way (for reasons just look at their ads).
Sukriti_B_
Hi
I am facing problem regarding Pin installation in windows 7.
Do you have any good tutorials?
Harold_G_Intel
You might try posting your question here: https://groups.yahoo.com/neo/groups/pinheads/info
Regards, Hal
Intel(R) Developer Zone Support
http://software.intel.com
*Other names and brands may be claimed as the property of others.
srijoni_m_
I would like to use Pin compatible on ARM architecture. I am not able to find any download link for the same. Kindly can you let me knwo the download path for the same. Will the pintools for linux OS present in path https://software.intel.com/en-us/articles/pintool-downloads  be compatible for ARM.
Thanking in Advance
Harold_G_Intel
Please join the pinheads Yahoo* group and ask this question there. http://tech.groups.yahoo.com/group/pinheads
Regards, Hal
KAUSHIK_S_
Please tell me how to generate the PIN PLUG-IN for ECLIPSE, I use windows Xp and MinGW compiler. please help me. Thank You
KAUSHIK_S_
I had run the pintool8 manual program inscount0.cpp in visual studio & mingw and got the errors please help me to solve it
the errors are attached
KAUSHIK_S_
Subject: Error while compiling the manual examples using the PIN tool with the command "make all"
Dear all
I am new to the pintools. I am using PIN for my M.tech project.
Details of software I am using are as follows
1. OS- Microsoft Windows XP [Version 5.1.2600]
2. Compiler MinGW Version 2, June 1991& Microsoft visual studio 2010 express
3.Pin tool package "pin-2.13-62141-msvc8-windows" Rev-62141,Date
Nov,22,2013,Compiler Kit- VC8
4. Cygwin.
I am trying to build the manual examples of PIN and getting following
messages while building the tools using "make all" command: in dos
command prompt
 ------------------------------------message---------------------------
C:\pin-2.12-58423-msvc8-windows\source\tools\ManualExamples>make all
link /DLL /EXPORT:main /NODEFAULTLIB /NOLOGO /INCREMENTAL:NO /MACHINE:x86 /ENTRY
:Ptrace_DllMainCRTStartup@12 /BASE:0x55000000 /OPT:REF  /out:obj-ia32/inscount0.
dll obj-ia32/inscount0.obj  /LIBPATH:../../../ia32/lib /LIBPATH:../../../ia32/li
b-ext /LIBPATH:../../../extras/xed2-ia32/lib pin.lib libxed.lib libcpmt.lib libc
mt.lib pinvm.lib kernel32.lib ntdll-32.lib
link: extra operand '/NODEFAULTLIB'
Try 'link --help' for more information.
../../../source/tools/Config/makefile.default.rules:156: recipe for target 'obj-
ia32/inscount0.dll' failed
make: *** [obj-ia32/inscount0.dll] Error 1
------------------------------message end------------------------------
Please help me to solve the problem
you can directly email me the solution email add= abirsarkar1987@gmail.com
thanks
Kaushik Sarkar
M.Tech (cse) cu
Harold_G_Intel
Regards, Hal
Manish_G_1
Hi All, I am facing issue using pin on linux 4.0. Has anyone else face the same issue.
Terminal Output
pin/source/tools/ManualExamples$ ../../../pin -t obj-intel64/inscount0.so -- /bin/ls
E: 4.0 is not a supported linux release
Does pin not support latest linux kernel?
http://stackoverflow.com/questions/35511380/intel-pin-tool-on-linux-4-0
Any suggestions would be really helpful. Thanks! Manish
Hao_L_1
Hi Everyone. I want to write a pintool to record the frame pointer of each function call at runtime. Is there any API function that can be used to retrieve the current frame pointer.  I tried to instrument the binary by adding a function call  _builtin_frame_address() at the end of each function call. It seems that the stack addresses was messed up. I think maybe it is because pin does dynamic instrumentation. Any idea of how to solve the problem?
Nadeen_G_Intel
Is it normal that using INS_MemoryOperandCount(ins) from within the trace subroutine of pinatrace and then calling it from RecordMemWrite predicated call routine display different results.
if (INS_MemoryOperandIsWritten(ins, memOp))
            INS_InsertPredicatedCall(
                ins, IPOINT_BEFORE, (AFUNPTR)RecordMemWrite,
                IARG_INST_PTR,
                IARG_MEMORYOP_EA, memOp,IARG_PTR,ins,
                IARG_END);
VOID RecordMemWrite(ADDRINT * ip, ADDRINT * addr,INS ins)
cout<<INS_MemoryOperandCount(ins);
SergeyKostrov
Valued Contributor II
Yes. But I would use a CRT printf function inside of RecordMemWrite instead of cout C++ stream. Also, I hope that you know about https://software.intel.com/sites/landingpage/pintool/docs/53271/Pin/html/group__INS__BASIC__API__GEN__IA32.html
Rohit_P_1
Hi I am trying to use the Intel Pin tool to emulate some new instructions. I am using the x86_64/ intel64 architecture. I am trying to use opcodes which are undefined in the original architecture, as new instructions. So I am using a c program which calls these instructions using the asm functions.
For example I am using the opcode 0x17, which is undefined in x86 to emulate a new instruction. However when I run an instruction trace from the Pin tool, I see that 0x17 is used by some other instruction which is "add" and my when I run the Pin tool with my  c program executable, I keep getting the Illegal instruction program. I am not able to figure out the actual instruction trace, and I feel that it is probably not the x86 instruction trace I am expecting.
Can anyone suggest what I am doing wrong?
Singla__Priyanka
I am trying to use PIN tool with a trace driven simulator. I want to feed the traces (generated by the PIN tool) to the simulator by using shared memory.  For this, I wrote a tool in which I create a shared memory region by using "ftok() and shmget()" from "ipc.h and shm.h", respectively.
When I make (and link) the tool, the linker command fails with the following error for ftok and shmget:
Undefined symbols for architecture x86_64:
ld: symbol(s) not found for architecture x86_64
clang: error: linker command failed with exit code 1 (use -v to see invocation)
I am using the following libraries -lpin -lxed -lpin3dwarf -nostdlib -lstlport-dynamic -lm-dynamic -lc-dynamic -lunwind-dynamic while linking. However, if I add the  libc library using "-lc", then I am able to successfully compile my code, but when i run it, then pin is unable to load the compiled library.
I am using Pin 3.7 (kit:97619 for OS X) on macOS High Sierra, with LLVM version 9.1.0 (clang-902.0.39.2). Any suggestions woud really be helpful.
luis__leo
Dear all
4. Cygwin.
command prompt
thanks
Kaushik Sarkar
M.Tech (cse) cu
hi,sarkar
i have the same problem as you met.May you give me advice? thank you in advance.
------------msg start--------------
b-ext /LIBPATH:../../../extras/xed-ia32/lib pin.lib libxed.lib libcpmt.lib libcm
make: *** [../../../source/tools/Config/makefile.default.rules:178: obj-ia32/ins
count0.dll] Error 1
-----------msg end--------------
Shilpa_B_
What is the right way to instrument R programs using PIN. I tried running pin tool "pinatrace.so" to trace memory addresses for reads and writes using the following commands:
../../../pin -follow_execv -t obj-intel64/pinatrace.so -- /home/shlpa/R-3.5.3/bin/R -f hello.R    and
../../../pin -follow_execv -t obj-intel64/pinatrace.so -- /home/shilpa/R-3.5.3/bin/Rscript hello.R
I am wondering whether -follow_execv option should be used? I notice in my trace file output (pinatrace.out) that after #eof line gets printed, then the trace for next line is not printed correctly. Also, whether trace output file should be opened in "w" or "a" mode?
I have also posted in pinheads yahoo group but did not get any reply.
Any help is appreciated.
Shilpa
