Software Archive
Read-only legacy content
17060 Discussions
preference name="target-device" value="handset" not working
Francesco_F_
After upgrading to the IntelXDK build 3088 my additions.xml file setting for target-device set to handset seems to be ignored as iTunes connect is complaining I need to upload iPad screenshots.
Additions.xml file setting:
<preference name="target-device" value="handset" />
When I look at the build log I can see the following:
 --target-device iphone --target-device ipad --minimum-deployment-target 8.0
Not sure if I'm missing something new or the backend build service has issues. Does anyone have a solution for this?
Thanks in advance :-)
Francesco
Swati_S_Intel1
Please make sure you are putting
under the
<platform name="ios"> tag.
Francesco_F_
Hi Swati,
Thanks for your suggestion. I tried what you suggested for the additions.xml file but it didn't work:
<platform name="ios"><preference name="target-device" value="handset" /></platform>
I also tried:
<!-- +iOS --><preference name="target-device" value="handset" />
Both still produce
--target-device iphone --target-device ipad in the output logs.
I noticed in my intelxdk.config.ios.xml file I have two <platform name="ios"> xml nodes:
1. <platform name="ios"><preference name="Orientation" value="portrait"/></platform>
2. <platform name="ios"><preference name="target-device" value="handset"/></platform>
Not sure if this is having any impact. Is there anything else you could suggest?
Francesco
Pamela_H_Intel
Thank you Francesco for creating this post. Paul was able to duplicate the problem. It seems to be a Cordova bug, but we are trying to find a work around. Please see: https://software.intel.com/en-us/forums/intel-xdk/topic/549481#comment-1866851
Francesco_F_
Hi Intel,
do you guys have any news on a possible solution for this issue?
thanks
Francesco
PaulF_IntelCorp
Francesco -- the issue is still under investigation and is marked as a "must-fix" for our next release. It is definitely a Cordova bug, a patch for the Cordova problem has not been identified at this time.
