Software Archive
Read-only legacy content
17060 Discussions
problem running start-agent.sh
EngKean_L_Intel
I have booted into Galileo using the SD card image downloaded from SD card (200MB Zipped).
Tried to run the start-agent.sh script in /usr/lib/node_modules/iotkit-agent/ directory, but the following error appear: "forever: command not found"
root@clanton:~# cd /usr/lib/node_modules/iotkit-agent/
root@clanton:/usr/lib/node_modules/iotkit-agent# ./start-agent.sh
 IoT Kit Agent
./start-agent.sh: line 17: forever: command not found
done
Brendan_L_Intel
please run the agent from /usr/bin/iotkit-agent. Note it's probably already running so do a `killall node` first & make sure your date/time is correct.
EngKean_L_Intel
There is no /usr/bin/iotkit-agent directory. I am using the original image downloaded without any changes.
Should I install the iotkit agent first?
Brendan_L_Intel
My bad, had a quick look and that simlink isn't there in those old images :) Just follow what the init script does:
NODEJS="/usr/lib/node_modules"
cd ${NODEJS}/iotkit-agent/
${NODEJS}/forever/bin/forever start -m 1 \
              -a -l "/tmp/forever.log" \
              --sourceDir ${NODEJS}/iotkit-agent \
              --minUptime 1s \
              --spinSleepTime 3s agent.js
so node agent.js from /usr/lib/node_modules should be what you run. start-iotkit script is from upstream and is not tailored to work on our images.
Cheers
Matthias_H_Intel
Hi Brendan,
if you call the current downloadable images "old images" - what are the right "new images"? where to get them?
Cheers,
Matthias
EngKean_L_Intel
when you said "start-iotkit script is from upstream", what do you mean by upstream?
How to relate this iotkit-agent on Galileo and the enableiot.com cloud hosting?
Brendan_L_Intel
This is upstream for the enableiot.com client:
https://github.com/enableiot/
https://github.com/enableiot/iotkit-agent
https://github.com/enableiot/iotkit-samples
You build them from git :) http://git.yoctoproject.org/cgit/cgit.cgi/meta-intel-iot-devkit/log/?h=devkit-next
Matthias_H_Intel
Brendan Le Foll (Intel) wrote:
You build them from git :) http://git.yoctoproject.org/cgit/cgit.cgi/meta-intel-iot-devkit/log/?h=d...
how do I see on git whether it's a daily version or a tested version? Referring to the actual full images as "old images" I assume there is at least a release candidate snapshot? Is there a specific git branch for those?
Todd_S_Intel
I ran into a similar issue as the original poster.   What fixed it for me was to run the following:
npm install forever -g
it seems this step was skipped when i ran setup-agent.sh
