Software Archive
Read-only legacy content
problems using non-commercial use license
Burcin_E_
I am trying to use Intel® Parallel Studio XE for Linux with a non-commercial license on my Gentoo workstation. The install process could not validate the serial number or display a code for offline validation, so I decided to install using a license file.
After copying the license file information from the registration center page into /opt/intel/licenses/license.lic, I get the following from icc:
$ export INTEL_LICENSE_FILE=/opt/intel/licenses/license.lic
$ ./icc
Error: A license for CCompL is not available (-8,130).
License file(s) used were (in this order):
    1.  Trusted Storage
**  2.  /opt/intel/licenses/license.lic
**  3.  /mnt/disk/burcin/intel/composer_xe_2013_sp1.3.174/Licenses
**  4.  /home/burcin/intel/licenses/license.lic
**  5.  /home/burcin/intel/licenses/nlicense.lic
**  6.  /Users/Shared/Library/Application Support/Intel/Licenses
**  7.  /mnt/disk/burcin/intel/composer_xe_2013_sp1.3.174/bin/intel64/*.lic
Please visit http://software.intel.com/sites/support/ if you require technical assistance.
icc: error #10052: could not checkout FLEXlm license
AFAICT, the tools that some in the installer say that the license file is valid:
~/.../parallel_studio_xe_2013_sp1_update3/pset $ tools/chklic.x64 -c /opt/intel/licenses/license.lic -a -f CCompL
License file = </opt/intel/licenses/license.lic>
    feature name:                  CCompL (INCREMENT line)
    (license is valid, i.e., has a valid signature)
    serial number:                 ************
    license expires:               perpetual license (does not expire)
    license maintenance expires:   2015.0505
    type of license:               uncounted (unlimited number of users)
    allowed platforms:
            i86_r          (IA-32 architecture; Linux*)
            i86_re         (IA-32 architecture; Linux*)
            it64_lr        (IA-64 architecture; Linux*)
            it64_re        (IA-64 architecture; Linux*)
            amd64_re       (Intel(R) 64 architecture; Linux*)
        *Other brands and names are the property of their respective owners.
    VENDOR_STRING= string contents:
            SUPPORT=<NCOM>
            https://registrationcenter.intel.com
    (feature can be authenticated, i.e., can actually be checked out)
The forum doesn't let me upload the log file I get with INTEL_LMD_DEBUG set.
I'd appreciate any help resolving this issue.
Hubert_H_Intel
Burcin,
Make sure you license file is really on the right place as specified with INTEL_LICENSE_FILE and readable for all users.
Check with:
   ls -al /opt/Intel/licenses/license.lic
and add read permissions if required:
   # chmod +r /opt/Intel/licenses/license.lic (requires (sudo)root rights)
If that dosn't help, send me the LMD log file. Please reply using the 'Send Author A Message' link where you can attach the log file.
Regards, Hubert.
