Software Archive
Read-only legacy content
17060 Discussions
question
Omar_l_
Good day I have a question, does the apk that builds intelXDK me if you can climb to the play store? The reason is that the e tried 2 times and the deleted for the following reasons: Violation of intellectual property and impersonation or deceptive conduct provisions of Content Policy. I could help Thanks.
Elroy_A_Intel
The apk(s) built by Intel XDK Build system doesn't check if the project violates intellectually property guidelines or legal restrictions. As the developer of the project, you are responsible for attributing the source code and files that you use from a third party source.
Hamilton_Tenório_da_
Valued Contributor I
Do you have a file song (link .mp3) in APP? Maybe this.
Omar_l_
Thanks for your answers, here I leave the apk project would appreciate help me check. --->Dropbox<--- Thank You.
You send us the APK file. Here we can´t see anything, because it is compiled.
PaulF_IntelCorp
The APK is a ZIP file, you can open it and inspect the contents using a standard ZIP tool. If files have been obfuscated you might have trouble, but usually it's not too hard to inspect the contents by unzipping the APK.
