Windows Vista Home Premium (6.0, Build 6000) (6000.vista_gdr.071023-1545)
Language: English (Regional Setting: English)
System Manufacturer: TOSHIBA
System Model: Equium L40
BIOS: BIOS Date: 09/19/07 Ver: V1.60
Processor: Intel Celeron CPU 530 @ 1.73GHz, ~1.7GHz
Memory: 1014MB RAM
Page File: 915MB used, 1368MB available
Windows Dir: C:Windows
DirectX Version: DirectX 10
DX Setup Parameters: Not found
DxDiag Version: 6.00.6000.16386 32bit Unicode
Card name: Mobile Intel 965 Express Chipset Family
Manufacturer: Intel Corporation
Chip type: Mobile Intel 965 Express Chipset Family
DAC type: Internal
Device Key: EnumPCIVEN_8086&DEV_2A02&SUBSYS_FF401179&REV_03
Display Memory: 251 MB
Dedicated Memory: 0 MB
Shared Memory: 251 MB
Current Mode: 1280 x 800 (32 bit) (60Hz)
Monitor: Generic PnP Monitor
Driver Name: igdumdx32.dll
Driver Version: 7.15.0010.1472 (English)
DDI Version: 9Ex
Driver Attributes: Final Retail
Driver Date/Size: 4/18/2008 18:12:18, 552960 bytes
I a have solution to a problem that plagues many players!
I too have been having a problem where about three mins after logging into
WoW the screen goes black for 4-5 seconds, and then continues to do so every
30 seconds or so.
Here are my system specs.
GTW GT5412
OS: Vista Home Premium 32-Bit
Processor: Intel Core 2 1.80Ghz
Ram: 2038MB
Video Card: Intel 82945G Express Chipset Family.
I read all over on the internet trying to fix it, and everyone said to
download the 02/04/07 drivers from intel.com but every time I would run the
installer it would tell me they weren't made for my computer.
Here is how I eventually got it to work.
Step 1:
Download the 02/04/07 drivers from Intel (Version # 15.1) Put them somewhere
you'll remember. (Desktop)
http://downloadcenter.intel.com/Filt...eng&sType=prev
Step 2:
Go to [Start -> Control Panel -> Security -> Turn automatic updating on or
off (Under Windows Update) -> Select "Check for updates but let me choose
whether to download and install them.
Step 3:
Go to [Start -> Control Panel -> System and Maintenance -> Device Manager ->
Tell Vista to Continue -> Display Adapters -> Right-click and uninstall your
current drivers.
Step 4:
Restart your computer. When Vista opens you will get a message that it is
installing "VGA adapter drivers"
Step 5:
Run "winvista_151" (Driver installer you downloaded earlier)
It should work - and if it comes up with a "Unknown error" than just try
running the installer again.
It worked without a hitch for me, and for my girlfriend's computer too. Hope
it works for all you guys too!
dont worry if your pc goes black for a wile it will have to be tured off manualy then your
pc will go throu so pc things dont wory its ok when its done u will have to restart it again
then it will be FIXED!!:)
IT WILL WORK FOR U i did it on 3 PCs and all fix ok do try
email me at tlkonier@yahoo.com ok tell me if u like it hope i helped u
