Software Archive
Read-only legacy content
17061 Discussions
"Open With" menu to attached file in email client
Joannes_P_
I'm trying to open a .txt file it could pop up a menu as "Open with..." and my app should be in the list inside of Gmail or some email client app.
I had success with file manager but not other explorers such as download folder, etc.
There is a screenshot, my app called TESTP it worked fine.
In email client, it won't show my app in the menu:
Here is my part of build.xml
        <intent-filter>
        <action android:name="android.intent.action.VIEW"></action>
        <category android:name="android.intent.category.LAUNCHER" />
        <category android:name="android.intent.category.DEFAULT"></category>
        <category android:name="android.intent.category.BROWSABLE"></category>
        <data android:scheme="content"/>
        <data android:host="*" />
        <data android:mimeType="application/octet-stream"/>
        <!-- <data android:mimeType="application/vnd.google-earth.kml+xml" /> -->
        <data android:pathPattern=".*\\.txt" />
        </intent-filter>
Also I'm looking a snippet for iOS devices and the solution.
Anthony_H_Intel
Hi Joannes-
I think you are almost there, but some of the details in your intent filter are not right.
Specifically, I think you need scheme to be "file" instead of "content", but you might need to change some other details...
Take a look at this tutorial for Android:
How to list your cordova app in "open with" menu in Android and handle the intent event
If you want more background information, also take a look at the official documentation:
Allowing Other Apps to Start Your Activity
For iOS, I wasn't able to find a tutorial, but the README for the Intent plugin referred to in the Android tutorial has iOS instructions.
You can use the custom-config plugin referred to in the previous tutorial to add the section you need to your info.plist.
Hope this helps!
Tony
