Software Archive
Read-only legacy content
17060 Discussions
"Target destination already exist" during project opening
Maxim_P_1
Hello! I try to open Intel XDK project maked via export from Construt 2,
and got this error:  https://postimg.org/image/3uk6ss4dj/
Before i launched XDK update to version 3400 and added "cranberrygame"s Game and Admob plugins to my Construct 2 project.
I removed scratch folder - did not help
The project does not open at all. Very need help )
Pamela_H_Intel
Maxim,
It's possible that your directory structure needs to be modified. We wrap apps as Cordova packages. Cordova changed some project formatting several months ago, requiring that XDK apps have a particular structure, i.e. your index.html must be in www, your plugins directory must not be in www. I have attached an image to show a good structure. Please check your structure. You may need to move some files around. I recommend that you make a backup copy of your project before modifying it.
Pamela
Maxim_P_1
Yes, Construct 2 started to use the correct folder structure after these Cordova changes. Also Construct 2 create Intel XDK project file, which removes the need to import files and configure the plugins manually. And it worked until now.
Pamela_H_Intel
Okay, Maxim. We've had a few reports of this issue. The engineer suggests using the fix in this post:
https://software.intel.com/en-us/forums/intel-xdk/topic/640827#comment-1876620
Let us know if that helps.
Maxim_P_1
Thank you! I will try it
Maxim_P_1
including intelxdk.upload.request.txt did not help. Moreover, I unistalled XDK and installed v.3088  and got same result.
Pamela_H_Intel
Maxim,
So with 3088 your project opens? But with 3400 it won't open?
