Software Archive
Read-only legacy content
공지
17060 토론
rejected app in the apple
Antonio_M_2
초급자
780 조회수
Dear Forum,
i'm trying to upload my app on itunes connect but every time it be rejected for this error:
"Thank you for your resubmission. The previous issue remains unresolved.
2.2 Details
We discovered one or more bugs in your app when reviewed on iPad running iOS 8.4 and iPhone running iOS 8.4 on both Wi-Fi and cellular networks.
App launches into a white screen.
The steps to reproduce are:
Launch app.
Next Steps
Please run your app on a device to identify the issue(s), then revise and resubmit your app for review.
If we misunderstood the intended behavior of your app, please reply to this message in the Resolution Center to provide information on how these features were intended to work.
For new apps, uninstall all previous versions of your app from a device, then install and follow the steps to reproduce the issue(s). For updates, install the new version as an update to the previous version, then follow the steps to reproduce the issue(s).
Resources
If you have difficulty reproducing a reported issue, please try testing the workflow described in Technical Q&A QA1764: How to reproduce bugs reported against App Store submissions.
If you have code-level questions after utilizing the above resources, you may wish to consult with Apple Developer Technical Support. When the DTS engineer follows up with you, please be ready to provide:
- complete details of your rejection issue(s)
- screenshots
- steps to reproduce the issue(s)
symbolicated crash logs - if your issue results in a crash log"
Please help me
0 포인트
3 응답
Brandon_K_Intel
780 조회수
Have you tried running your application on an iOS 8.4 Device? And have you tried using the on device debugging to help solve this issue?
0 포인트
Antonio_M_2
초급자
780 조회수
hi, yes i've tryed on ios 8.4 and it work perfectly. I dont know how can i fix.
0 포인트
John_H_Intel2
직원
780 조회수
Sounds to me like you need to file an appeal with Apple and ask for further info on why they are rejecting it. Find out if they are testing on an actual device or a simulator.
Also, if you want, I can send you a UDID to add to the provisioning profile and you can then send me an ad hoc build to install on an 8.4 iphone 4 to see if I can reproduce their issue.
0 포인트
응답
