Software Archive
Read-only legacy content
17060 Discussions
saving RGB and depth images
ajinkya_A_
As in the documentation I have used SetFileName() function to save the RGB and Depth image to the specified file location. But that's not saving anything. The code runs without error, but nothing gets saved.
Here's my code:
void RecordORPlayback(pxcCHAR *file, pxcBool record)
    // Create a SenseManager instance
   PXCSenseManager *sm=PXCSenseManager::CreateInstance();
   // Set file recording or playback
    sm->QueryCaptureManager()->SetFileName(file,record);
   // Select the color stream
   sm->EnableStream(PXCCapture::STREAM_TYPE_COLOR,640,480,0);
   sm->EnableStream(PXCCapture::STREAM_TYPE_DEPTH,640,480,0);
   PXCImage *colorIm, *depthIm;
   // Initialize and Record 300 frames
   sm->Init();
   for (int i=0;i<300;i++) {
       // This function blocks until a color sample is ready
       if (sm->AcquireFrame(true)<PXC_STATUS_NO_ERROR) break;
       // Retrieve the sample
       PXCCapture::Sample *sample=sm->QuerySample();
       // Work on the image sample->color
        colorIm=sample->color;
        depthIm=sample->depth;
       // Go fetching the next sample
       sm->ReleaseFrame();
   // close down
   sm->Release();
I have no idea how to save the output. Any suggestions?
Thanks in advance
samontab
Valued Contributor II
Have a look at the Clip Editor example
ajinkya_A_
@Samontab
Yes, but I didn't understand how to connect that with camera_viewer.cpp . Is there any other way to achieve my goals?
samontab
Well, you have the bytes of the image in memory so you could use a 3rd party library for saving it.
At the lowest level this could be for example libjpeg, or libpng.
If you are planning to process the images as well, you could use OpenCV which has those libraries and more already built-in.
