In the input/output window of my QuickWin application I would like to have the window automatically set the scroll bar to the bottom of the last line of text. I know that I can use the SendMessage with WM_VSCROLL, SB_LINEDOWN parameters to scroll down one line, and I know that the GetTextPosition routine will tell me how many lines of text I have, but I need to know where the scroll bar is in order to tell it how many lines to scroll up or down. I have not been able to get the GetScrollPos or SetScrollPos commands to work (do they only work in a complete Windows application?), or know if they would even do the trick for me if I could get them to work.
They should do the trick -- perhaps you just didn't implemented them
right way? It should look something like this:
Btw, did they fix the QW scrollbars so that the thumb is
proportional to visible portion of the data? If not, take
a look into SetScrollInfo(hChild, SB_VERT, SI, .TRUE.),
where SI is of type T_SCROLLINFO, which contains nMin,
nMax and nPage members.
HTH
Jugoslav
USE DFWIN USE MSFLIB INTEGER:: hChild INTEGER, PARAMETER:: iChildUnit = 11 ... OPEN(iChildUnit, FILE='USER',...) ... hChild=GetHWNDQQ(iChildUnit) iSt=SetScrollPos(hChild, SB_VERT, newPosition, .TRUE.)
HTH
Jugoslav
Thanks for the reply! I am probably being dense, but I still have problems. The SetScrollPos command does indeed move the position of the thumb in the scroll bar, but it doesn't actually scroll the text in the window. If I could get the GetScrollInfo command to work, then I could at least figure out how many lines up or down I need to go to reach the end of the text and then use the SB_LINEUP or SB_LINEDOWN to go there, although that seems a very indirect way to do what I want to do. When I include the statement:
TYPE (T_SCROLLINFO) si
the program compiles okay, but it doesn't recognize the variables si.nMin, si.nMax, or si.nPage. Instead I get the error, "This is not a field name that is defined in the encompassing structure" for each of them.
When I enter the Help Index, I cannot find any information about "T_SCROLLINFO." Instead, I find the "SCROLLINFO" structure defined with the nMin, nMax, nPage, etc. elements. However, when I include the statement,
TYPE (SCROLLINFO) si
in the program, I get the error message "This derived type name has not been declared." So, apparently I am not including the correct library or module or something?
Bill
Bill
I misread your original post, so I posted the sample with SetScrollPos --
however, I don't see why GetScrollPos wouldn't work. Regarding the setting scrollbar position, you're right -- SetScrollPos only sets the thumb position -- sorry, it was long time ago since I worked with it. However,
you can use SendMessage with SB_THUMBPOSITION flag set to get
the window scrolled to the desired position:
> something?
You did (almost) everything OK -- this time, it's Compaq that's at fault.
It's their translation of C Win32 headers that's inconsistent, especially
of those that were inherited from Micro$oft FPS (there was
a lot of talk about it in this and the old Forum). The Win32 types are
always prefixed with T_ in DFWIN (and its "sub-modules"); member names
should be the same as described in help. However, they made an
exception for reasons unknown to me with SCROLLINFO: its members
are declared as Min, Max, Page etc., not nMin, nMax, nPage as in help.
So, proper declaration is T_SCROLLINFO, and it should be looked in help
under SCROLLINFO. Generally, it's always a good idea when using
a Win32 function or type to do a "Find in Files" in Program Files/.../DF/Include to take a look on type declaration or INTERFACE block.
Jugoslav
iSt=SendMessage(hChild, WM_VSCROLL, SB_THUMBPOSITION + & ISHL(newPosition,16) , 0)
> something?
Jugoslav
Thank you very much! It now works the way I had hoped. My final subroutine, if of any interest, is:
NumRows is obviously the integer setting the number of rows in the window when originally created.
Subroutine ResetScrollPosition
USE dflib
USE dfwin
IMPLICIT NONE
TYPE (RCCOORD) textpos
INTEGER(2) NumRows
INTEGER status,win_handle,newPos
COMMON /Handles/ win_handle,NumRows
Call GetTextPosition(textpos)
If (textpos.row.GT.20) then
si.Size = sizeof(si)
si.Mask = SIF_ALL
status = GetScrollInfo(win_handle,SB_VERT,si)
newPos = ISHL(NINT(si.Max*(textpos.row-20.0)/NumRows),16) + SB_THUMBPOSITION
status = SendMessage(win_handle,WM_VSCROLL,newPos,0)
End if
Return
End
Topic Options
