Software Archive
Read-only legacy content
set delay function
zeroman_z_
set delay some seconds for function
setTimeout(function(){
intel.xdk.player.playSound(intel.xdk.webRoot + "sounds/1.wav");
}, 3000);
not work ??
Swati_S_Intel1
First, the XDK base object has been deprecated, so intel.xdk.webRoot will not work. Please use window.location.href to get the webroot. See this post on how to do that :  http://stackoverflow.com/a/21392617
Second, to use the player APIs, you have to add Intel XDK Player plugin through plugins management under Projects tab.
zeroman_z_
ok
thanks
how can i set input number from input text as variable x ?
zeroman_z_
}, x);
x is variable from input text box how i can do it ?
Swati_S_Intel1
Can you clarify the question little bit? Also, if it's not related to this topic then please open another topic.
zeroman_z_
its another question its my 1st use of intel XDK
how can get text number like 7 from text box to variable x value
