Software Archive
Read-only legacy content
17060 Discussions
simple cilk_spawn Segmentation Fault
Chris_Szalwinski
I'm having difficulty running a simple test case using cilk_spawn.  I'm compiling under gcc 4.9.0 20130520.
The following fib2010.cpp example, executes in 0.028s without cilk and takes 0.376s with cilk as long as I set the number of workers to 1.  If I change the number of workers to any number greater than one, I get a segmentation fault.
// fib2010.1.cpp
#include <iostream>
#include <cilk/cilk.h>
#include <cilk/cilk_api.h>
int fib(int n)
    if (n < 2)
        return n;
    int x = cilk_spawn fib(n-1);
    int y = fib(n-2);
    cilk_sync;
    return x + y;
int main(int argc, char* argv[])
    std::cout << "No of workers = " << __cilkrts_get_nworkers() << std::endl;
    int n = 32;
    std::cout << "fib(" << n << ") = " << fib(n) << std::endl;
The hardware is Dual Core AMD Opteron 8220.
Barry_T_Intel
That looks like an ancient compiler. I just tried it with a current version (pulled 20-Mar) without any problem:
[bash]$ g++ -fcilkplus -lcilkrts -o fib fib.cpp
$ ./fib
fib(32) = 3524578 - calculated using 8 workers
$ g++ --version
g++ (GCC) 4.9.0 20140320 (experimental)
Copyright (C) 2014 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
$[/bash]
   - Barry
